why does power just fall off after spraying to 3rd?
Old Nov 7, 2005 | 04:00 PM
AINT SKEERED's Avatar
Default why does power just fall off after spraying to 3rd?
I was trying out the new kit and I sprayed a 75 shot from first to the middle of 3rd and then at 5800 rpm's the car just took a nose dive. WOuld the air filter maybe not be flowing enough air or is it doing something crazy with the mass air? this is a dry kit.
Old Nov 7, 2005 | 04:23 PM
SPEEDYws6's Avatar
No, you spray a dry kit before the MAF.
Old Nov 7, 2005 | 04:25 PM
ws6sojuiced01's Avatar
Default ah
ah dry kit my bad
Old Nov 7, 2005 | 08:57 PM
Yes this is a dry kit , I have it before the mass air sensor. Any thoughts?
Old Nov 7, 2005 | 09:14 PM
SPEEDYws6's Avatar
Maybe you are loosing bottle pressure? Check your spark plugs.
Old Nov 7, 2005 | 09:35 PM
Robert56's Avatar
How's your fuel system, ie: injector size and fuel pump? I have had this problem before and it was just running out of fuel. Is it really falling on it's face big time?
Robert
Old Nov 8, 2005 | 07:36 AM
I have a walbro 255 with 30lb svo injectors.
That should support well over my 420 rwhp and a 75 shot. I am going to change the fuel filter again and the spark plugs are tr6's but I have had them in since Last december . I will change them and see.
Old Nov 8, 2005 | 01:26 PM
rebersole2's Avatar
I vote for fuel starvation also. As I found out this weekend, you still need fuel for the Niutrous to work.
Old Nov 8, 2005 | 01:38 PM
Robert56's Avatar
I agree your fuel system is up to the task if working properly. Have you checked the FPSS if you have one, as they sometimes are not adjusted correctly and can cause problems.
Robert
Old Nov 8, 2005 | 02:46 PM
Matt@HSW's Avatar
Do you have a hot wire kit for your walbro pump?
Matt
Old Nov 9, 2005 | 08:27 AM
jimmyblue's Avatar
Moderator
Can you see the O2 sensor voltages and any knock
retard when this goes on? That would do a lot to
narrow down the cause.
Old Nov 10, 2005 | 04:55 AM
I can get a scan tool to check this, I will look to see what I can find. Thanks, chad.
