Sprayed for the 1st time today, it was fun!
I was with my wife, so I wanted to just take it easy. I have an 01 C5 Vette, A4, 4000 stall.
I was on an open tollway with no cars, and I was doing about 50 MPH at about 2,500 RPM's. Had my window switch at 4,000 and 6,200. I had my bottle pressure at 1,000 PSI.
I dropped the hammer at 55mph and it kinda felt wierd at first (cause it down shifted) but then I felt the nitrous go, it just started to feel really fast and pull
, now it wasn't as HARD as I thought it would be, but again I was already at 50-55 before I hit it. I did it again from about 55 MPH and it was hauling some major but, but it was smoother this time but fast.
Now I want to do it from a slower MPH or out of the hole. I bet that senario allows you to REALLY feel the Torque! vs. from a 55 MPH roll.
It was cool though and can't wait to do it again. I have a slow leak in my back right new Nitto 555 DR, so I need ot get that figured out.
Just FYI: I am Running 22 degrees timing (took some out, but might put some back in later) . On the spray My A/F was 11.2 so I was really FAT on the dyno and only picked up 90 RWHP, (Have NX's 150 fuel Jets and 100 hp N20 Jets) I am thinking I will swap at least one side of my dual nozzle fuel jet, or maybe both of the fuel jets back to a 100 shot Fuel Jet (#18 vs. the #22 have on each side now for my fuel jet) which will lean it out and bring my A/F higher than 11.2 and make it more responsive.
Pretty cool.
ALso it took my bottle about 10 minutes to get from 600 to 1,000 psi. Is that normal? Or does that mean I need to get it filled again? Between the testing of the purge and the dyno runs etc I bet I went through a lot?
Also I have the NX Bottle heater and solonoid that shuts it off at a certain psi (I think?) what is the PSI it gets toi before it shuts off?
Also when the bottle heater is on the square red switch panel light on my NX Panel is soooo dim you can't see it in the day, and it barely lights up very bright at night. I guess this is normal?
Thanks
This stuff id fun, can't wait to see what my track times are and might go Friday
Nice run. When are you spraying, On Off etc? Are you on DR's?
We need ot go head to head now that I have the Juice. I was running low 7's NA, but my first few runs on the bottle Dec 3rd were 7.50 at 98.33 MPH with a 1.90 60'. Dissapointing, buy I will get better.
What is your name and when are you going again?
We will race next time. Good to hear from you. You raced my friend Scott the Big Guy
BTW, I used ot have a Yank SS3600, before I traded it for the SS4000. The SS3600 will be wayyyyy better on the Gas. the 4,000 is a little tall for the bottle, but in the 1/4 it might be OK
