Will 2 10lb bottles fit.......
Old Dec 26, 2005 | 10:06 AM
95ttoplt1's Avatar
Default Will 2 10lb bottles fit.......
In the spare tire well on a 4th gen? I searched and came up with nothing, Thanks
Old Dec 26, 2005 | 10:50 AM
Caribe's Avatar
Probably not, here is a pic with a one 10 pound bottle. Not much room under the bottle.
Old Dec 26, 2005 | 11:12 AM
95ttoplt1's Avatar
I was thinking vertically like so
Old Dec 26, 2005 | 02:07 PM
n2ojunkie's Avatar
I did it but its not nhra leagle. I filled the area with foam and then cut two openings for the bottles to stand up with a slight lean forward at the top. It wont pass tech I know but they also wont move around and they were pretty tight at first, but 3 yrs later and they will pull out easier now. I am going to work on somthing this winter to make it leagel and still fit 2 bottles.
Old Dec 27, 2005 | 12:10 AM
95ttoplt1's Avatar
Why isn't it legal? And do you have any pictures?
Old Dec 27, 2005 | 09:41 AM
n2ojunkie's Avatar
Its not leagel because theres nothing really holding them down. They couldfly out if I was to roll the car or get hit. I just rely on how tight everything is to keep them in place. Like I said I have had it like this for 3 yrs and never had a bottle move. I've been to the track like this but no one has ever asked to see the bottles so I guess I am alright so far. I am thinking of doing a halo type bracket over both botttles and leaveing the foam where its at. that would just hold the bottles in place in a roll over. Here is one pic I found when I was piecing it together just to give you an idea of how I did it. I changed a few pieces after this and the foam is a lot tighter. The foam I used cam in 2"x2" strips so I used spray adhesive to glue them together. And I think I went another layer higher also, I went up to top of ridge.
Old Dec 27, 2005 | 11:17 AM
95ttoplt1's Avatar
sweet man, I have brackets for both bottles so I will probably build some brackets or something for them, thanks for the help and if you got pictures of what they look like finished I would interested
Old Dec 29, 2005 | 10:11 AM
02NHRA's Avatar
That's crazy, and I thought stuffing 1 15#er in there was a pita.
Old Dec 30, 2005 | 11:39 AM
n2ojunkie's Avatar
Hey it works and they dont move . Like I said I plan on doing something to make it leagel because I plan on being a little more noticeable at the track this year and they may want to start looking.
