whats a safe shot to use?
Old Dec 31, 2005 | 12:06 AM
transamls1woa's Avatar
Default whats a safe shot to use?
Whats a shot that maybe wouldnt be to much for a 98 trans am a4, it runs good, like would 50 be ok probably and should it be dry, or will a wet shot be alright, or could i shoot more than 50?
Old Dec 31, 2005 | 01:04 AM
Z2K_MrJ's Avatar
Board Certified Idiot
Your CAR could Handel a 150 Wet right out of the BOX. with No problems And No MOD needed.. The Dry i would have to say around 75-100 all cars handel Dry shots differ when stock and Not TUNED.. WET allways seems the LESS hassel of the 2.From what i have came apon
Old Dec 31, 2005 | 02:04 AM
white2001s10's Avatar
100 dry shot is very safe.
Old Dec 31, 2005 | 09:35 AM
MetallicaMatt's Avatar
if you got any larger than 100 dry, you'll need bigger injectors
if you go wet, 150 and you'll be fine...should consider a larger fuel pump to be extra safe, but its your call
Old Dec 31, 2005 | 12:46 PM
sprayinss's Avatar
150 out of the box is fine,but like said above get a fuel pump just for insurance to be safe about it,or u culd run 125 and not worry at all,hope this helps
Old Jan 1, 2006 | 03:08 AM
brad8266's Avatar
50 is more than safe. Like said, 150 wet can be handled stock. Do a search on this, it has been beaten to death here, you will find tons on valuable info in this forum on anything nitrous related. My suggestion for a near stock LS1 wanting to run nitrous: 150 wet shot, NGK TR6 plugs gapped around.038, high flow fuel pump, window switch, and a FPSS for added protection. A combo like this will be completely safe.
Old Jan 1, 2006 | 05:39 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would do the wet over dry for the hassle reason alone.
Old Jan 1, 2006 | 03:17 PM
stangereater's Avatar
One of my buddies has a 98 TA with 150k never had any work done he's running a 100 shot dry
Old Jan 1, 2006 | 04:55 PM
2002LS1Z28's Avatar
a 50 shot will not make u happy. go with a 150.
