Nitrous Setup (pics)
Old Jan 1, 2006 | 10:38 PM
01_ram-air's Avatar
Default Nitrous Setup (pics)
I know that a lot of people have much cleaner set-ups, but mine was done on a very small budget so be nice. Got a new camera so I figured I would test her out. Enjoy!
Old Jan 1, 2006 | 10:56 PM
code4's Avatar
Looks like everthing needed to
Does the end of your purge line stay in place when activated. I doesn't look like it is supported. I got a purge kit for Xmas & I am getting ready to install it in the same local with poly hose.
Old Jan 1, 2006 | 11:07 PM
01_ram-air's Avatar
Drilled holes through the plastic piece that the line is running under and zip tied her up. Can't see it and it won't move.
Old Jan 2, 2006 | 12:08 AM
B.W.'s Avatar
Nice, how much are you spraying on that setup? Stock stall with that ET?
Old Jan 2, 2006 | 12:19 AM
minesfaster's Avatar
BADASS i think i might go the N20 route best bang for the buck.
01ramair how many miles on the clock?
Old Jan 2, 2006 | 12:28 AM
ws6sojuiced01's Avatar
Damn if that is stock stall u must be juicing out the hole are you? A friend of mine made me a noid mount like this makes for alot cleaner install. just an idea to get your noids mounted up on somthing.
Old Jan 2, 2006 | 01:09 AM
227Hawk's Avatar
Looks good could use some clean up.
Nice times what shot you running?
Hawk
Old Jan 2, 2006 | 01:26 AM
Gold Z's Avatar
Why don't you mount your bottle pressure guage on the bottle instead of under the hood. That way you can check your bottle pressure with a quick glance.
Old Jan 2, 2006 | 07:45 AM
00SS4780's Avatar
I like that bottle bracket mount. Looks good!
Old Jan 2, 2006 | 09:37 AM
01_ram-air's Avatar
ST Yank 4000 stall. Spraying a 100 shot outta the hole. And I'll be getting a second N20 gauge for the bottle. 66,000 on the clock.
Old Jan 2, 2006 | 09:44 AM
scalemaster's Avatar
here's mine
Old Jan 2, 2006 | 11:05 AM
01_ram-air's Avatar
Very nice setup scalemaster.
Old Jan 2, 2006 | 11:22 AM
Cheater's Avatar
are those firebird wheels powercoated in your hatch area???
Old Jan 2, 2006 | 11:25 AM
01_ram-air's Avatar
Yep. good eye.
Old Jan 2, 2006 | 11:33 AM
Cheater's Avatar
that looks bad azz with the blk. wheels
Old Jan 2, 2006 | 11:34 PM
01_ram-air's Avatar
Thanks
Old Jan 3, 2006 | 12:22 AM
shaZZam's Avatar
Did that WOT switch bracket come with your kit or did you make it?
Old Jan 3, 2006 | 10:35 AM
01_ram-air's Avatar
I made it myself.
Old Jan 3, 2006 | 02:19 PM
DevonsZ's Avatar
Nice ride man. Do you have any n/a times? I just put the bottle to my stalled car and am wondering about what times to expect. *100hp shot rated at the crank*
Old Jan 3, 2006 | 03:12 PM
bad6as's Avatar
devonsZ im guessing you could pull of a 11.5
