Thought's on the halo system?
Old Jan 13, 2006 | 05:41 PM
dannyz's Avatar
Default Thought's on the halo system?
Anyone here run Nito Dave's Halo system?
It look's nice and I'd like any feedback.
I take it from the picture it sandwhich''s in between the lid and the air box.
Is that right?
Thank's guy's.
Old Jan 13, 2006 | 05:43 PM
bad6as's Avatar
it shows an 80 as the max on his site. can it go as much as a 125?
Old Jan 13, 2006 | 06:04 PM
dannyz's Avatar
Yeah, I guess it can. There's a note on the bottom of the add that say's it can go higher.
Old Jan 13, 2006 | 06:07 PM
bad6as's Avatar
imo looks nice and very stealthy. im still undecided on the kit i want.
i did a rough est. on a kit and all the goodies and im looking about $1500.
i wouldent just buy a kit and call it a day, all the goodies make n20 even better
Old Jan 13, 2006 | 06:20 PM
dannyz's Avatar
What all are you getting?
I want the heater, window sw. and fpss plus a couple of odd's and end's but it's still under a grand.
Old Jan 13, 2006 | 06:25 PM
bad6as's Avatar
n20 kit-500
window switch-130
fpss-40
purge kit w/ v purge-130
spare tire mount bracket-45
the ele wot switch-100
n20 filter-50
bottle warmer-150
bottle opener-200
bottle blanket-30
total is under 1500 but i said 1500 cuz theres all ways something
i wanna know more about daves wiring harness
Old Jan 13, 2006 | 06:26 PM
Nitro Dave's Nitrous Outlet's Avatar
The Halo system is the only dry system of its kind. It makes for a nice clean install. The system has quite a few perks to it as well. It has a 300 hp solenoid so it will have no problem producing more than 80 rear wheel hp..
Dave
Old Jan 13, 2006 | 06:27 PM
bad6as's Avatar
can i get more info on your wiring harness
Old Jan 13, 2006 | 06:37 PM
dannyz's Avatar
Me also. I forgot about that harness you came out with untill bad6as mentioned it.
Tell us about it.
Old Jan 14, 2006 | 02:12 AM
shaZZam's Avatar
https://ls1tech.com/forums/nitrous-oxide/435359-nitro-dave-s-customer-life-pics-inside.html
Old Jan 14, 2006 | 04:59 AM
dannyz's Avatar
O.K., so the harness is a crowd pleaser, but what does it entail?
Like can you run everything off of it? Heater, remote opener, etc?
If I can hook up all of my electrical to it in an orderly fashion it sound's like a "must have".
Old Jan 15, 2006 | 11:59 PM
The harness makes installing your nitrous system very easy. It also gives you a professional install at half the time. We offer it in a custom build to suit, Basic system only or a all in one..
Dave
Old Jan 16, 2006 | 12:02 AM
bad6as's Avatar
so if i was buying a dry kit, window switch, remote bottle opner, bottle heater, purge, fpss, and i wanted them under the arm rest, with the bottle in teh spare tire area. you could build it exactley to that?
Old Jan 16, 2006 | 12:05 AM
You bet.. No problem..
Dave
Old Jan 16, 2006 | 12:07 AM
bad6as's Avatar
well i guess for me to fullley understand the wiring i would need to have n20 1st.
i know i want dry, but i dunno if i want the halo or shark nossel kit, sell me on one over the other
Old Jan 16, 2006 | 12:22 AM
Matt D's Avatar
Retired Street Racer
EDIT- Thanks Dave
Old Jan 16, 2006 | 06:52 PM
Yes sir.. No problem..
Thank You
Dave
Old Jan 16, 2006 | 06:54 PM
bad6as's Avatar
would it make more cents to pice togeather my own kit rather then buying one?
Old Jan 16, 2006 | 06:56 PM
If you have alot of part laying around it is doable. However By the time you are done you may end up spending just as much. If you are trying to save cost check out our single nozzle kits for 349.00.. I can also help you with indavidual parts.
Dave
Old Jan 16, 2006 | 06:59 PM
bad6as's Avatar
do you have any pics of your harness?
