Stock rods okay for spray?
14 Second Truck Club
I've almost got everything to rebuild my LS1 shortblock. I plan on using Speed Pro Forged Pistons/Rings and the ARP Cracked Rod Bolts with the stock rods. Would that be good for an occasional 100-150 shot? Thanks.
You would most likely be okay with stock rods, but while you are in the engine, go with forged pistons AND rods. It is worth the extra little bit of money!
Stock rods are very strong, but all it takes is one nice strong hole shot with sticky tires and then you risk having to go into the motor again and spend all that labor/money just because you didnt spend a few extra hundred bucks to begin with. Also, if a rod does fail, I believe it will usually snap (kiss the block goodbye). ...whereas forged will usually bend if anything
Originally Posted by Ravenous T\A
can stock rods & forged pistons with good bolts handle a 200 shot?
Who has stock forged rods in their LS1? Mine are powdered metal. As a matter of fact, all the LS1s I have built have powdered metal cracked rods. If you don't think the rod will shatter just think, that is how they made the two piece rod on the big end in the first place, they crack it in two.
Mike
HP numbers in the sig are on stock short block with arp rod bolts
