Going Fast
Help me with a setup. I want to trap 120mph with the least amount of boltons and a realtively big dose of pills. Whats specifically the easiest way i can do this? thanks
IMO your best bet is to get a full exhaust and a very good converter first. They will give you the biggest bang for your trouble to bring your MPH up closer to 110 before the nitrous.
Then you can use a $300 dry shot of nitrous... smaller shot to be more reliable like you're asking.
You simply keep jetting up the dry shot until you get the performance you're looking for.
You will not need to change your rear gear or anything inside the engine besides running a colder sparkplug.
You will need to de-screen your MAF for running a dry shot.
Cars with highway gears tend to be slower on the motor, but gain more on the bottle, so no problem there.
https://ls1tech.com/forums/nitrous-oxide/422521-max-dry-shot-stock-fuel-system-28lb-injectors.html
Homeslice (tm) had 3.15 rear gears, exhaust, and a dry nitrous system and put up 127 MPH with a few N2O supporting mods like plugs, tricker box, and running the engine cool.
So which nitrous package should i get. I was looking at the NX MAF kit. But i would have to save up for a little while. Are there any good quality, safe, cheaper ways to go?
Look at HSW they have a real nice kit they just came out with, has there name on it. Has real nice 3 port nitrous noid. Give Matt a call at Harris Speed Works.
