Direct Port... hard vs. braided lines
Thanks braided lines would be better because the steel ones u have to bend cut and measure etc.. which can be a PITA....
see with direct port you want to bend the pipes so there is no radical sharp turns that could hinder or restrict flow. you want all the lines the same and un restricted.
i think you could accomplish this better with the lines because it flexes..
but i could be wrong.
Hopefully Robert Dave or Ricky would chime in.
also with the braided lines they have flex so if you dropped something on them, hit it going in it wouldnt be the end of the world itd flex... with the hard lines u could bend it and itd be a PITA.
However Braided hoses add to the rice of the kit. With braided hoses you will also need a way of mounting the distribution block since the support is no longer there.
Dave
Robert
Don't be fooled by the changing jet statements, no offense but changing with either is a PITA. It takes me 50 minutes for all 16 with hardline.
Too me (if money is no object), it comes down to the look you like; that's why I went with hardlines over braided, simply for the look...
http://www.harrisspeedworks.com/shop/home.php?cat=358
Matt
