140k Bottom end Still Sprayable?
Old Feb 10, 2006 | 09:55 PM
Speed Density's Avatar
hashtagBMW
Default 140k Bottom end Still Sprayable?
Just wondering, i had a thought. I would think you could, but it wouldnt be safe.
Old Feb 10, 2006 | 09:58 PM
02Vortech's Avatar
maybe a 25 to 45 shot
Old Feb 10, 2006 | 10:47 PM
b00sted's Avatar
If it's in good shape why not? I can see if it had a knock or blow by...
My car has 150k on it, runs like it has 40k...I gonna throw a 125 shot on it eventually.
Old Feb 10, 2006 | 11:05 PM
Bow94z's Avatar
Seems like alot of ppl spray with high mileage LT1's, Mine has 140K as well and it's getting a NX wet 75/100 shot to it this season, as long as the motor seems strong, doesnt have any problems and you have enough fuel to supply to it..i think it will be ok. Just dont go using it 3 times a day 7 day a week, it will never last!
Check out this thread i made... Some of the stories will blow your mind!
http://web.camaross.com/forums/showthread.php?t=399754
Old Feb 10, 2006 | 11:53 PM
Flash99's Avatar
I think it would be fine if your rings are still sealing well. I wouldnt go more then 100 shot though. I had a friend with 135K miles on an LT1 Run use it a few times, the car has 155K and still running well.
Old Feb 11, 2006 | 12:34 AM
hashtagBMW
I wouldnt go bigger then 50 on my block.
Old Feb 11, 2006 | 06:29 PM
Super Speed's Avatar
Do a compression test and if the number dont range too far its all good but if they are spread apart its a definate no no
Old Feb 11, 2006 | 07:26 PM
dogger's Avatar
depends a good friend of mine had 130k on his motor. ran a 125 shot for a while then went 175 shot for a while all in a attemt to blow her which didn't happen so he took of the nos and put on a blower and that motor still is runnigng strock but he did have to replace to blown head gasket's.
Old Feb 11, 2006 | 08:15 PM
Cheater's Avatar
Dont say it,Spray it!!!
Old Feb 11, 2006 | 09:45 PM
Dune-LS1's Avatar
A "lose motor" is better than a tight motor, to a point. I'd be worried about the stock rod bolts more than anything. But with that said, I'd spray it if it was mine.
Zilla
Old Feb 11, 2006 | 11:24 PM
CadillacEXTon27's Avatar
Spray it!! If it goes UPGRADE , YEAH YEAH!!!
