new test:nx noid vs dynotune
well i just tried my latest test, my last test was with both nx and dynotune large noids and they both worked well for me and gave me the power i needed, this time i was testing the smaller noids, i used a nx small noid with a .063 orifice rated at 150 rear wheel hp and a dynotune small noid with a .074 orifice rated at 175 flywheel hp, both were jetted with a .062 jet and pressure at 1000 psi, now the results , the nx noid gave me a max of 107 rwhp and it started tapering off slightly on the top end, the dynotune noid gave me 135 rwhp till redline, that just my results, its not to be biased in any way because there both good products but i just needed to check for myself in my aplication if the rating were real or not, once again both were tested with a .062 jet, i feel that if i had a larger jet in the dynotune noid i might have got a few more hp cause of the larger orifice in the noid, thank you for reading
sorry forgot to mention it was with a single fogger dry kit, airfuel was around 11.6/1 and went slightly richer with the dynotune noid probally cause it was flowing more nitrous and the maf corrected for it
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
This all seems sensible, two .062 in series is going to
restrict flow more than a .062/.073 tandem. Though I
have to question the sense of using a solenoid so close
in size to the fed nozzle, I would expect icing potential
as roughly half of the total pressure drop (hence temp
drop) is happening at the solenoid. Did you notice any
such thing esp. on the NX smaller-orifice one? Wonder
if there is any concern with condensation, icing keeping
the plunger from snapoing closed, esp. if you're in a
humid environment?
humid environment?
i was thinking that with the nx noid that the reason it seemed to taper off on the top end was because it was freezing or icing if that is even possible im not sure, both noids felt to be the same external temp after use
Closed ex-Sponsor Account
Ricky
LS1TECH Sponsor
Did you run the solonoids in line with each other? Or did you run one solonoid take it out and run the other? I was confused on the post and then the follow up posts? Thanks for posting we always like to see how are product does and the results say it all. If you can get the files we would be glad to post them. Just email them to us as we have the dynojet software. I knew there was a reason people keep buying our products - and I thought it was us
Dean
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dean
Dean
Dean
Robert
