Discussion: Nitrous nozzle design and is it important?
Robert
I think it was me really that got this ball rolling about nozzles. The test Mrr23 did was not perfect...but good. And it showed one nozzle making marginally better HP than another. But all test criteria where not exact. So I dont think people dug into it much.
And I think that each manufacturer thinks thier nozzle is the best. NX, TNT, CF etc. But what are those reasons they think they are the best? Because thier nozzles make better HP? Thats a loaded question...more HP at what flow, at what AF level, with what supporting hardware?
If I remember...Ricky wanted to see the tests and did call out for some pretty strict criteria if MRR23 was able to do it. He even provided the nozzle to that independant party.The NX nozzle came out slightly ahead. But test conditions where not perfect and could have lead to the NX nozzle making that extra power. I didnt really see NX or anyone else make crazy claims concerning the test and left it at that. I thought the NX nozzle may substantially outperform the Nytrex becuse I thought it may have been possible the Nytrex was a sub par design. Obviously that wasnt the case and it worked pretty good.
Now you have to admit...when you guys posted the CF nozzle thread...there were some pretty big claims made. And it was said that you guys had all the flow sheets and information and dyno graphs to back that claim up. Obviously the test information provided was less than stellar. I think thats what really led to the scrutiny. IMO its always better to let the proof make the claims..and not the other way around.
anyways, here's the cliff notes version for you guys.
test #1 = ny-trex nozzle vs nx nozzle
Run #33 - ny-trex nozzle with NX brand .062/.033 jets 457.29 rwhp 454.86 rwtq A/F 11.0-11.5:1.
Run #34 - NX nozzle with NX brand .062/.033 jets 465.99 rwhp 455.05 rwtq A/F 12.0:1 until 6300 rpms.
test #2 ny-trez nozzle .062"/.031" vs nx nozzle .062"/.033"
Run #35 - ny-trex nozzle with NX brand .062/.031 jets 461.50 rwhp 460.48 rwtq A/F 12.0:1 until 6300 rpms.
test #5 ny-trex nozzle vs nx nozzle with larger solenoid
Run #37 - ny-trex nozzle with NX brand .062/.033 jets 475.04 rwhp 463.61 rwtq A/F 11.9-12.2:1.
This was with the 40040 Monster-shot nitrous solenoid. It has a .125 orifice opening.
Run #38 - NX nozzle with NX brand .062/.033 jets 481.85 rwhp 486.51 A/F 12.7:1 until 5900 rpms.
when using the exact same jetting with the small solenoid, the nx nozzle made 8.7 rwhp more.
both gains had some to do with the .5 leaner a/f ratio. so, in test #2, i made the a/f ratio the same between the nozzles at 12.0:1 in this scenario, the nx made 4.49 rwhp more still. but, the ny-trex nozzle made 5.43 rwtq more.
And as you said...the change you made that had the biggest measurable difference was going to a larger orifice. Same jets.
Again that points towards correct combinations (lines, noids, nozzles, fittings) to achieve max flow rates for a given jet size. And depending on which item in a given setup is MOST deficient...changing that most deficient item out will have the biggest net gain. In your case...so far it has been the smaller noids.
Bit it COULD even be a nozzle if that nozzle is seriously substandard or was being run at too high a flow. Thats why on a 200 or a 250+ shot on a single nozzle...i would not be surpised to begin to see differences in power. Its possible certain nozzles could begin to see issues at very high levels. We rearely run single nozzles that high.
IMO, if you are trying to run 300 rwhp n2o, you should be on direct port. or two stages of single nozzle.
i still want to see if the NX MAF kit will produce more over the shark nozzle. but that's a hefty price for me to try out.
this pic was before i put the larger solenoid on the passenger side system.
Robert
this is why you won't see like companies compete with each other on the same exact field. for example, now that we've seen the nx nozzle best the nx nozzle by 4.49 rwhp given the same a/f ratio, which would you buy?
Robert
Robert
Robert
The reason and the only reason there were skeptics and nea sayers in the nitrous direct thread was lack of data. INcomplete slow to get poor data thats all. You make a claim and you should be able to back it up NOW. Especially if future customers are looking to buy something. Once CF retests the nozzle again and shows data I am sure there will still be some that disagree, my self tests are just that tests, nothing more nothing less.
Ricky
Ricky
Robert
