First time out on the juice
Old Mar 3, 2006 | 11:50 PM
ArchOverseer's Avatar
Default First time out on the juice
Tonight was alright, I guess. The track wasn't hooking worth a DAMN. I ran 13.1 @ 105 with a 1.94 60....I usually cut high 1.7's. =/ Anyhow, I ran the 13.1 on motor, and decided to give the nitrous a try. Cut an even worse 60 (1.97) and ended up running 12.12 @ 117. Mods in sig. So it cut a good second off, and upped my trap 12 mph. I know it had 11's in it with a good 60, but the cam is going in tomorrow, so I didn't push it any further. Btw, this was done on the 100 shot. Haven't upped to 150 yet! - Chris
Old Mar 4, 2006 | 12:26 AM
1 BLOWN V8's Avatar
You will get 11's no problem if you can get it to hook better. If you can get back to the 1.7 60 foot that will put you in the 11.9
I take it you have a dry shot also.
Old Mar 4, 2006 | 12:27 AM
1MEANGTO's Avatar
Yeah isn't the bottle great!!!
I don't even have any NA times with my new setup. I'm a nitrous junkie.
Great times man !!!!!!!!!!
Old Mar 4, 2006 | 12:38 AM
No dry, wet shot.
Old Mar 4, 2006 | 01:01 AM
1MEANGTO's Avatar
That thing should be capapble of mid 11's on wet Lets see what the cam does???
What tires do you run????
Old Mar 4, 2006 | 01:17 AM
Nitto DR's. I wish I could go back in time, as they're brand new....And I really don't think I heated them up properly. Not at all. But, oh well. I can't wait for the bumpstick to go in, then it's off to HPE to get tuned and see what it'll do at the track after that. =D
Old Mar 4, 2006 | 01:55 AM
1MEANGTO's Avatar
I'm getting 1.55 on a set of M/T et street biasply's. I just got a set of hoosier drag radials with the same "no tread pattern" as the e/t streets I think they may hook harder.
Old Mar 4, 2006 | 06:23 PM
bad6as's Avatar
stock 3.32 10 bolt??
Old Mar 4, 2006 | 06:57 PM
3.42 10 bolt, yes....It's gonna go boom soon enough, I can feel it. But hey, might as well have fun with it while it lasts. It spun a good bit last night but still hooked at the end of first, and after that it was a fun ride. Now that the car's down with the cam, I can't wait to get it tuned and head back to see some mid to low 11's, hooking hopefully. =D
Old Mar 4, 2006 | 08:06 PM
MetallicaMatt's Avatar
i just bought some and they said they require a heat cycle
does this mean before you start using the tires? or just heat them up before you make a pass?
Old Mar 4, 2006 | 09:32 PM
From what I understand you really gotta burn that first layer of tread off before they start hookin' decent. Guess that's what I didn't do.....Oh well, lesson learned. Next time.
Old Mar 6, 2006 | 08:58 PM
setxws6's Avatar
Yea, maybe if you heated them a little more dummy and drop some pressure, you might have gotten 11's!!!
Old Mar 6, 2006 | 09:08 PM
1MEANGTO's Avatar
jeez-ozzle
Old Mar 6, 2006 | 09:28 PM
daryl2cb@yahoo.com's Avatar
yeah, look for better times, I went 11's with 150 wet and cat back only, I have not even got numbers since cam headers intake and throttle body and retune, good luck
Old Mar 7, 2006 | 01:47 AM
I know 11's were there. Had I heated them up and been smart about it, 11's were there. That was my only pass on the juice. Oh well, the cam install is about finished, and soon up to HPE to tune, and I'll be back out there....117.96 is not a bad mph I think, seen people run easy 11's on less mph.
Old Mar 7, 2006 | 09:32 AM
bad6as's Avatar
be for the cam and with out the n20 what was your best time
Old Mar 7, 2006 | 09:39 AM
ApacheDrill's Avatar
its like crack.. next you will be going dp 300 shot..
Old Mar 7, 2006 | 12:52 PM
z_speedfreak's Avatar
those are some nice times. what cam are you putting in, or what are the specs if its a custom one and you dont mind sharing
Old Mar 7, 2006 | 02:49 PM
It's the TR 230/236. It's advertised as I believe 230/236 .590/.598 on a 112. On my box it came out to be 231/237 .594/.607 on a 112 +4. I think it'll do pretty decent.
Old Mar 7, 2006 | 03:59 PM
1MEANGTO's Avatar
Wow +4
