Nitrous Help!!
as long as the car is running well, and generally healthy you shouldn't need a tune.
injectors will be fine.
do you have a window switch??
You're correct that injectors won't need changing because the kit is wet, but your fuel system is having to supply extra fuel regardless, so be sure that your pump is capable and, depending on mileage, you might want to replace your filter.
As far as plugs go, the NGK's are good, but remember- no matter how much everyone loves them, NGK didn't really have nitrous use in mind when they made these plugs. ZEX makes a Nitrous specific plug that you might want to look into. Although I've heard mixed reviews, I've used the plugs myself on both nitrous and turbo applications and have never had a problem. I'd recommend them.
However, the Zex's have a triple electrode tip that dispurses the spark more generously which is definitely a plus with high horsepower nitrous applications.
I'm a fan of the "Better to be safe than sorry" philosophy, but hey, if you want to save a few bucks, spring for the NGK's.
i have the fuel safety switch...that just kills the nitrous if sumthing goes wrong...right??
