Did some Bench Flow testing
).Pulled everything out in the garage today, and started with the bottle heater, wired that up for the test and set the pressure switch to about 1050 psi. That DynoTune Heater kicked butt! Was 45 degrees in the garage and the bottle pressure was about 450 psi, I had my doubts as to getting the bottle up to 950, but it did it pretty handily, then I tweaked it to about 1050.
I made a bench flow test plate for the dry nozzles that mimicked the Blackwing Air Intake, I spaced the nozzles where they will fit on the blackwing and flowed them, it appears they will flow nicely inside the filter, the patterns end up about 2" forward of the nozzle location and as they lose pressure go out to about 3".
Talked with Dave about posting the plate flow test, he did not mind at all. Here is a vid of the Dry Test and the Nitrous Dave Plate flow Test.
Right Click Save Target, its about 5 megs.
Beer's Bench Flow Test Video
Now to start pulling the passenger seat and trim...
Cheers
Beer
Thanks for the Vid Beer. Nice work.
Dave
Gary in Texas, thanks for the stickers.... I have them, but need to put them on. i JUST sprayed Sat for the first time at the track in the 1.4. It was scary, but really FUN and now I am not scared at all, but do respect the power and am careful.
Thanks again and good luck with your install...................
WOW cool video. I like the way you test and measure everything and are very methodical in your application tetsing on everything from nitrous jets to labels for the nitrous buttons to your custon nitrous panel plate you made....
I am impressed with that wall of Nitrous it forms. Getting my turkey baster today (LOL I will explain later in my "Put my plate in today" thread...), hoping to install the plate today or tomorrow.
Sticking to the plan on the two stage, although I really want throw a fuel pump in next to exploit both stages...but it will have to wait, to many projects.
Beer
Dave
Its a wet system, correct?How much spray was sprayed through that thing? Man that was cool.
