NX 150wet 1/4 time on stock 94 z28???
Old 04-03-2006 | 08:52 AM
Camaro94SS's Avatar
Default NX 150wet 1/4 time on stock 94 z28???
What 1/4 times do you think NX 150 wet shot will get me on a stock 94 Z28, LT1 with only K&N cold air....?
Old 04-03-2006 | 11:47 AM
Bow94z's Avatar
What trans, gears, tires?
some have seen high 11's but prolly low 12's
Old 04-03-2006 | 12:31 PM
Camaro94SS's Avatar
A4 trans,stock gears, 9.5 wide street tires
Old 04-03-2006 | 01:01 PM
grubby98's Avatar
need to know if its an auto or a m6. let us now, but put some exhaust and a stall if its an auto or some 410 if a manual and spray it and you could see mid 11's. but right now with ur tires and setup i would say low 12s.
Old 04-03-2006 | 01:06 PM
The Guy in MY 99TA's Avatar
hmmm depending on N/A times.... I had a buddy that had a 93 trans am w/ a cold air and it ran 14.0's on motor and then ran 12.0s on a 150 shot.... but that was with drag radials. He put headers on it and a little bit more than stock converter and it ran 13.4's on motor and I don't think he even got back to the track with a kit back on it.
then another friend had a 6 speed car w/ a cold air and a tune and it went 13.3's on motor and 11.8's on a 150
Old 04-03-2006 | 01:07 PM
jessedale98's Avatar
Wow, your talking about 2.5 seconds off ur 1/4 time with a 150 shot on a stock lt1? I believe they runs 14s stock. so your saying they can run mid 11's with a 150 shot with only some tires and gears? I guess my 125 shot isnt doing somthing right, it hasnt even taken me off a full second. Let me know the secret
Old 04-03-2006 | 01:09 PM
grubby98's Avatar
when i had a 100 shot on my old 94 firebird, with crappy tires and just exhaust, i was able to get right at a second of my time, so im sure with a 150 and good tires and able to sprat out of the hole easily should be able to get 1.5 seconds or so. it all depends on when you can spray and no spin those tires. the sooner you spray the better your ET.
Old 04-03-2006 | 02:03 PM
Camaro94SS's Avatar
I know mustang 04's run liek 14.0 in 1/4 mile and I eat them alive all the time....My car also has no smog, no a/c, no heat, TB bypass....the cats are removed also....i think my car might run around 13.7 or 13.8 in 1/4....but i dont know
Quick Reply: NX 150wet 1/4 time on stock 94 z28???
