nozzle shootout results
Old Apr 13, 2006 | 03:21 PM
  #41
ALBERT@COLD FUSION's Avatar
Default Thanks
Originally Posted by mrr23
you like that, don't cha??? did it just for you. guys, i appreciate the thanks being handed out. i'd like to thank the sponsors that actually donated parts for the testing. without them, it would've taken longer to get this done and not have had as many to compare. i'll work some more tonight on the webpage and graphs. what i'll do is put a column with average a/f ratio. it was late and i didn't have the graphs in front of me at the time. so, i didn't want to put the wrong info up.
one nozzle that surprised me was the dynotune nozzle. it was right up there with the SHO and TNT. for a tiny nozzle, it put up a good fight. as far as the predator goes, well, maybe it's just my car. who knows. they are supposed to have another test performed shortly.
Thanks for all the hard work. One HUGE factor that I see that makes me scratch my head is the Dyno-tune nozzle is our standard nozzle that is in all of our kits. I'm saying "exact" same because they get them from one of our larger dealers that we supply!!! That being said, we know exactly how it performs against the Predator and it does not keep up. So, either the Dyno has a +/- factor of greater than X or something else was causing the odd results. Either way the best test is at the track. So pill it to kill it!!!
Old Apr 13, 2006 | 03:46 PM
  #42
860 Performance's Avatar
[/QUOTE] I'm saying "exact" same because they get them from one of our larger dealers that we supply!!! [/QUOTE]
So.... your saying that Cold Fusion produces the dynotune nozzle???????
Old Apr 13, 2006 | 03:47 PM
  #43
NXRICKY's Avatar
Closed ex-Sponsor Account
Well maybe not missing but forgot to chip in.
Old Apr 13, 2006 | 03:50 PM
  #44
where do we send money?
Old Apr 13, 2006 | 03:53 PM
  #45
So.... Cold Fusion produces the dynotune nozzle???????[/QUOTE]
YES. However, we do not know if they port or do modifications to it once they receive it. As i stated earlier they buy from a supplier that we supply. look at the picture it even has the brass nozzle fittings and we are the only company that makes those in brass without plating!!!! The nozzle is more like the NOS pro race nozzle than the vortec. the vortec is a bit different but same shape.
Old Apr 13, 2006 | 03:57 PM
  #46
Noyzee's Avatar
8 second mod
my dick is bigger then yours
they are nozzles, take it to the track, and jet the ***** off it, and go from there.
Old Apr 13, 2006 | 03:58 PM
  #47
now that was funny!!!
Old Apr 13, 2006 | 04:12 PM
  #48
Noyzee's Avatar
8 second mod
its true tho, the test was done, great big woopiethe air fuel in most of the graphs are not the same. if i was a computer guy i would show you, but go to the charts, the first one with the preditor vs what ever, the blue line is approx 14-1, the pink is 13-1 aprox. so your telling me on spray, 1-1 af makes no extra power? your telling me thats not a varyable?
give me a brake, go to the track test them out, buy a kit because you want it, because you like it, or because of a test done in one of the biggest bs forums around
by a kit that works for you and go for it.
the test is great, but to me, alot of waisted time that didnt prove a point.
prove a point, and make the af exact on every run, ect ect. then maybe, but like stated befor, heat soak, bla bla bla then comes into effect.
oh well.
Old Apr 13, 2006 | 04:18 PM
  #49
383LQ4SS's Avatar
I really dont think the minute differences are worthy of putting under a microscope at this point. I really wanted to see one nozzle STAND OUT. If you have to enlarge the graph to see differences and try to squeeze out a little leaner tune to make an extra 3-5 hp over another nozzle...then to me that doesnt show any clear winner.
What this really shows me...bottom line...its all about the flow capabilties of the entire kit. Nitrous flow = hp. Nitrous flow is MUCH more a factor in total HP than nozzle design.
For you guys to show that one nozzle has some type of advantage over another...your REALLY going to have to tighten the resolution on the testing. So much so that agin...I would say the differences are negligable.
To me manufacturer claims of overall nozzle superiority at medium HP levels are dead. I might focus on testing the limits of HP and consistency of tune at the very high flow rates and component quality.
Sorry to beat a dead horse but I do feel somewhat vindicated for the post I made a few months ago.
Here is a link to that post.
https://ls1tech.com/forums/nitrous-oxide/456725-discussion-nitrous-nozzle-design-important.html
The initial idea was:
I personally think all nozzles that are halfway decently built will perform just fine. Be it NX, TNT, NOS, HSW, NW, or CF or other. I think they will all perform within 1% of each other if the parameter of nitrous flow, fuel flow, ratio of that flow, bottle pressure etc are maintained.
I say that because I have yet to see any REAL evidence to the contrary. No one has done a test and posted proof that was not "tainted" in some way. The testing was always stopped short.
I am doing a small bit if chest beating here.....I was challenged by most in that thread.
ok..headed to the track to spray a 225 on the stock shortblock and shoot for deep 9s.
Old Apr 13, 2006 | 04:26 PM
  #50
mrr23's Avatar
actually, you are correct. i forgot to add dynotune to the list. thanks for catching that one. if there is nothing written to the side of the name, it's because they did not donate something to the testing. nothing bad. just giving credit where it's due.
Old Apr 13, 2006 | 04:31 PM
  #51
mrr23's Avatar
not worried about money. it's nice to offset the cost of buying your nozzle, but not necessary. don't want it to look like i'm out for freebies or to try and make money off this. if you want, i can send the nozzle back and get a refund. is that fair? if not, i'll just keep it as i paid for it from the donations that i received. so, technically, i didn't pay for it. i did pay for 4 bottles of nitrous. only used about 13 lbs though. again, not about the money.
Old Apr 13, 2006 | 04:37 PM
  #52
red91z's Avatar
LS1TECH Sponsor
383LQ4SS, No offense taken at all. Just pointing out some facts. Like everyone else said it's just a jet change.
Old Apr 13, 2006 | 04:38 PM
  #53
mrr23's Avatar
top HP should be next, same jetting on the spray side, but adjust the fuel side to get say a 13-1 af and see who makes the most at the same air fuel.
all dynos were done with the same .062" n2o jet. only change made was to the fuel side to try and achieve 12.0:1 a/f ratio.
Old Apr 13, 2006 | 04:43 PM
  #54
mrr23's Avatar
Originally Posted by nick@hsw
I am just trying to spark some conversation on what people are looking at in these graphs and maybe trying to learn why one nozzle is highlighted in red?
i highlighted it in red to show who made most hp and tq. which just happened to be the SHO nozzle. i just went in and highlighted in blue, the nozzle(s) that made most power and torque using the baseline .062/.033 jetting.
one thing to be learned here if anything is to wideband tune the nitrous. once i put the a/f ratios up, you'll notice how far in variance the readings are. granted none really got into a danger zone, IMO. but, some were in the 13:1 range, some were in the 12:1 range.
Old Apr 13, 2006 | 05:02 PM
  #55
NXJeremy's Avatar
Al, I would usually agree with the above statement. However, this is one of the things that jumps out at me the most about the results of this test. The nozzle that made the most hp did so using only a .5 oz more nitrous than the least amount of nitrous used by any one nozzle, and on the other hand, the nozzle that used the most nitrous didn't make the most hp. Granted, their is only a 1hp difference between the top two nozzles (SHO 424.82 and Dynotune 423.21) but the difference in the amount of nitrous those two used (SHO 8.75oz and Dynotune 10.25oz) I would think would make for more than a 1hp difference.
Old Apr 13, 2006 | 06:06 PM
  #56
mrr23's Avatar
started putting up more info about the runs.
Old Apr 13, 2006 | 06:18 PM
  #57
ws6sojuiced01's Avatar
Great job this will deff put more thought into ones mind when looking for a nozzle
thanks for your time in that one.
Old Apr 13, 2006 | 06:49 PM
  #58
mrr23's Avatar
ok. added a/f ratio @ 5000 rpms, temperature, humidity, absolute pressure, vapor pressure and correction factor. more stuff to cloud the mind
Old Apr 13, 2006 | 07:33 PM
  #59
mrr23's Avatar
first set of graphs are up. enjoy. i'll keep plugging away. this is going to take some time. at least i found a way to not waste paper and ink.
Old Apr 13, 2006 | 08:44 PM
  #60
CAT3's Avatar
Restricted User
Noyzee....wake up in a bad mood today, or just letting **** get under the skin? (reference the bs forum comment, ouch).
Al, you sir, have been declared vindicated! I just wanted to see any one of them jump far beyond all others, so I could WOW or something in reply. And or see an old *** nozzle that wouldnt be able to flow for its life so all the newer nozzles look awesome Good thing, I can picture the results in my head.
I guess I will continue to piece meal my nitrous stuff as I see fit, or find sales.
