Fuel psi safty??
Old Apr 14, 2006 | 09:14 AM
Noyzee's Avatar
8 second mod
Question Fuel psi safty??
how does this wire in?
does a hot leg go to one side, then out to the noid? or does it come from the wot? any diagram for it?
thanks
Old Apr 14, 2006 | 09:22 AM
860 Performance's Avatar
you usually use it to ground a signal side.
So you could run you window ground output, through it, to the relay.
thanks
Old Apr 14, 2006 | 09:27 AM
Noyzee's Avatar
8 second mod
ok, so window/wot switchto one side, and the other side to the relay?
im confused.
should have got a wet kit. lol
Old Apr 14, 2006 | 09:37 AM
Yeah it dosen't sound like I explained it very well.
You really need a diagram, to be clear. I'll look for one that is email-able
Old Apr 14, 2006 | 09:45 AM
Noyzee's Avatar
8 second mod
cool, thanks
Old Apr 14, 2006 | 09:46 AM
NXJeremy's Avatar
If you are using a relay in your system you will connect the ground wire from it to one side of the fuel pressure safety switch. The other side of the fuel pressure switch will be connected to the window switch.
If I remember correctly, you got the Trick window switch/TPS unit from Dave right? If so, then take the yellow wire and connect it to the fuel pressure switch.
So basically, you'll have the ground from the relay on one side and the yellow wire from the window switch on the other side.
Hope that wasn't too confusing, lol (I'm not big on trying to explain wiring, I usually end up confusing myself in process).
Old Apr 14, 2006 | 09:49 AM
Noyzee's Avatar
8 second mod
correct. i run that switch. accually, dave is looking for a diagram for that as well, the directions arnt so good.
a basic kit is easy, but this fancy stuff kills me. lol
i cant wait to throw my dual stage on, i sware its easyer then this. lol
Old Apr 14, 2006 | 11:38 AM
Nitro Dave's Nitrous Outlet's Avatar
Brad, I sent you an email. But I will aslo post this. Put the fpss in line with the wire from the window switch to pin 85 on the relay.
Dave
Old Apr 14, 2006 | 11:53 AM
Noyzee's Avatar
8 second mod
i thought that black box was a window/tpswot?
im even more confused now. that pic shows a wot?? and thats why i bought the window/wot.
i think i might say **** all the stupid safty ****, throw a basic wot on it, a heater, and hammer the ******* thing! wiring this thing is stupid.
thats why i stay away from all the fance pants ****!
Old Apr 14, 2006 | 12:02 PM
Noyzee's Avatar
8 second mod
Im all set!! THANKS vinny!!!!!!!!!!!!!!!!!!!!!!!!
i owe you a beer!!! or 12.
Old Apr 14, 2006 | 12:06 PM
Ok, If you are using the tps . Ignore the wot switch. The wire from the arming switch will go straight to the pin 86 on the relay.
THe Tach signal can either go to pin 10 (white wire on the pcm) Or the negative wire on the #6 coil wire.( I belive green Wire white tracer) THe TPS wire will go straight to the throttle position sensor Not sure on that wire. But iut reads 4.5 volts at wide open throttle.
Dave
Old Apr 14, 2006 | 12:08 PM
Noyzee's Avatar
8 second mod
Dave
yhea, thanks. vinny called me and walked me threw it. lol i hate wiring, and fancy stuff, thats why i never used it
Old Apr 14, 2006 | 01:06 PM
Wireing is my down fall also. Thats why Im always bugging NX RICKY.lol
He is the man of all wireing.
Dave
Old Apr 14, 2006 | 01:14 PM
Noyzee's Avatar
8 second mod
Dave
i dont mind simple wiring, but this stuff sucks. lol
