How much would you spray????
Old Apr 21, 2006 | 10:46 PM
RUTAN TA's Avatar
Default How much would you spray????
I have a 98 Trans am
00 block
stock crank
eagle 6.125 rods
custom JE pistons(floating pins)
file fit rings
titan sce headgaskets
compression @11.3
ported ls1 castings 2.055/1.60 flowing @318 at 600
comp cam 238/246 636/642 114lsa
patriot adj. rockers
patriot gold springs and tit. retainers
port matched LS6 int
walbro 340 pump
36lb injectors
arp studs head/main/rod
coated pistons
coated bearings
direct port fogger(nos)
stand alone fuel system
Old Apr 21, 2006 | 11:29 PM
BAD FNZ's Avatar
start off at 150 for a good base to see what the car does, and work your way up from there...
Old Apr 21, 2006 | 11:32 PM
RUTAN TA's Avatar
I should have stated that I was spraying my stock motor w/150. I am thinking @ starting at 150 and working my way to 300-350 range. Block and crank permitting.
Old Apr 21, 2006 | 11:37 PM
BAD FNZ's Avatar
Your crank should be fine along with your block... our cranks are good for 700+rwhp I would still start at the 150 even if you have forged internals. It's a good starting point.
Old Apr 23, 2006 | 12:06 AM
MyTA99's Avatar
RUTAN TA what kind of power are you making on that setup? Have you dyno'd it yet?
Old Apr 23, 2006 | 07:53 AM
RUTAN TA's Avatar
I have not dyno'd it yet,I am waiting on the machine shop to finish a few things and I am working on relocating my battery and building my fuel cell for my stand alone(I want at least a 3 gal. cell). I will post some numbers when its finished,should be sometime next month. I am also looking at a vacuum pump from Charlie from A&A.
Old Apr 23, 2006 | 09:34 PM
BAKED's Avatar
I wouldn't hesitate to spray 300-350 with that setup, that might just be me though.
Old Apr 23, 2006 | 10:33 PM
RUTAN TA's Avatar
Thats what I was thinking.I just thought I would get a little input.
Old Apr 24, 2006 | 06:29 AM
brad8266's Avatar
With the forged rods and pistons along with the good bolts that bottom end will hold up to a lot of power. And you also have a good fuel supply to go with it. Just be sure if you spray a big shot to have a good tune done to avoid detonation, which can and will destroy any motor.
Old Apr 24, 2006 | 06:35 AM
bad95killer's Avatar
very true , fuel is there no doubt but ya should get her tuned first then feed her with juiced as much as ya want man .
peace
Old Apr 24, 2006 | 08:25 AM
98redorangeta's Avatar
I dont think you will have any problem spraying in the 300 horspower range on that motor with some race gas but with out stages or a progressive controller you will probly be fighting a losing battle aginst traction.
