Window switch, tps, progressive programmer...IN ONE BOX!
Old Jun 9, 2006 | 08:44 AM
BadAssFast's Avatar
Lightbulb Window switch, tps, progressive programmer...IN ONE BOX!
Someone needs to make one. My idea is to simply hook power and noids directly to this jewel. Or does it already exist?
Old Jun 9, 2006 | 08:54 AM
Nitro Dave's Nitrous Outlet's Avatar
Macon. Right here.
http://www.nitrousoutlet.com/catalog...product_id=952
or
http://www.nitrousoutlet.com/catalog...roduct_id=1539
Dave
Old Jun 9, 2006 | 09:16 AM
BadAssFast's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Seems like I knew it all along!! LOL. If it was a snake...it would have bit me.
Old Jun 9, 2006 | 10:33 AM
Matt@HSW's Avatar
Yeah, quite a few on the market, I thought I sent you the instructions on our Edge controller months ago?
Matt
Old Jun 9, 2006 | 11:47 AM
BadAssFast's Avatar
Matt
I have some trouble shootiong to do on my system...that is the purpose of this inquiry. I got to thinking about how nice it would be to have things "black boxed" in a tidy package as far as subdividing the wiring between the TPS unit, the MSD Window Switch and the power relay for the solenoids...not to mention the potential for connections to wind up being faulty from the movement of the motor.
So Matt - Yep still have the paper work on it...thank you. At the time I was looking into simply logging perfromance. Now I am really thinking more in terms of simplifing installation. So with The Edge and The FJO piece seems like these pieces solve lots of potential issues. Same answser to different questions in a way.
Thanks - Macon
Old Jun 9, 2006 | 12:39 PM
Sunset'01Z's Avatar
that looks pretty cool, but i'm kinda confused in some areas. what does TPS stand for? and with this little box, i can basically controll when and how much the nitrous is shooting from my laptop, but will i have to have my laptop with me any time i want to shoot? or can i preprogram settings and leave it alone?
Old Jun 9, 2006 | 12:56 PM
BadAssFast's Avatar
TPS=Throttle Position Switch (No WOT (wide open throttle) switch required))
Edge does not require a laptop.
FJO does require a laptop.
I think i am correct here.
Old Jun 9, 2006 | 12:59 PM
Sunset'01Z's Avatar
does the FJO require me to have my laptop in the car whenever i'm spraying?
Old Jun 9, 2006 | 01:11 PM
BadAssFast's Avatar
NO!!! Just for programming!! Do it at home....go to the track!
Old Jun 9, 2006 | 01:19 PM
Sunset'01Z's Avatar
badass! thanks
Old Jun 9, 2006 | 02:03 PM
algws6's Avatar
hey dave, on the FJO Kit can you use the trans brake wire on a clutch switch? reason i ask is for the M6 guys that are using a 2 step to lauch and have ther RPM in the "window" and have the pedal to the floor.
Old Jun 9, 2006 | 03:51 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
yes you can use the trigger wire to disable the system. So in a clutch set up just set up a switch to close its contacts when pressed in. This will turn the system off.
Ricky
Old Jun 9, 2006 | 04:18 PM
BadAssFast's Avatar
Ricky
Hey Ricky...can you guess what i'm pondering?????
Old Jun 9, 2006 | 04:49 PM
algws6's Avatar
Ricky, does the polarity matter? i know when i had my harlen 2 step in my WS6 i just connected the wire directly into my pcm clutch wire. however, on my vette i had to use a relay.
Old Jun 14, 2006 | 07:58 PM
ZoFastSS's Avatar
Wink
I should of gotton one of those.
Old Jun 14, 2006 | 11:13 PM
Robert56's Avatar
Ricky
Hey Ricky, can you draw that up. i am pondering a 2-step and was wondering the same. I believe I know how to do it, but seeing it on paper is mucho better. Also, then we could add it to the wiring stickie. One question, for the old school guys that like the multi stage, is there any way to do 3-stages on any single controller, preferably the FJO. Man, I am telling you, my 3-stages and 3-ws wiring and the rest of my add ons is becoming a nightmare. I would like sometime to get it all drawn up and see if any one else has a more complicated wiring system. Which I would like to make more simple.
Robert
Old Jun 14, 2006 | 11:50 PM
CAT3's Avatar
Restricted User
I feel you on the wiring Robert. I am looking at a options to redo my entire Nitrous and controlling setup. Final will be two stages, two step, trans brake, line lock, heater, purge....WTFE else I can think of wiring into this bad boy. I like how Beer posted his switches being jumpered off each other, for ground. Now I am looking into a sheathed multi-wire cable, like CAT5e or something for carrying low load 12v signal. Not only reduce the scatter of wire, but make running it much easier. Got any suggestions?
Old Jun 15, 2006 | 12:15 AM
Robert56's Avatar
Yea, it's kinda fun though to see how complicated you can get it, and still be able to troubleshoot it.
7-relays
6-noids
5-toggle sws
2-bottle heaters
1-line lock
3-additional indicate lights
2-gauges fuel press/n20 press, both elect
1-LM1 wide band
1-Laptop
2-window sws
1-rpm activation sw
1-1st gear lock out for 2nd/3rd stages
1-purge
2-micro sws
and am certain that I am missing some stuff.
Then coming,
1-two step
1-micro sw activated kenny bell bap
1-3rd stage rpm on indicater light
1-additional purge
1-anything else I can think of to toss in the mix.
Robert
Old Jun 15, 2006 | 12:51 AM
CAT3's Avatar
Restricted User
Upt, Robert, you listed 1- purge twice you sly lil devil You definately got a lot more going on then I do. I actually thought about cutting it all down to one setup, with ProController..only two noids/1 WOT/1 Purge that way. Dunno.
Old Jun 15, 2006 | 09:38 AM
Dang Robert all those stages and parts
You should be running like 7s or 8s in the quarter
Dave
