Good Nitrous Converter? Have SS4000/Getting New Tranny Perfect Time
Title says it all. Have a Yank SS4000 2.6 STR Torque Converter and 3.42 gears in my 01 Vette. Have a 100 wet shotand sprayed only 2-3 times and althought my tranny is OK now (stock tranny) it will break soon and I might be getting a Level IV RPM Tranny soon. While my car is up there I was thinking maybe I should swap my SS4000 for a smaller stall?
Which one and why?
The SS4000 is cool, but I am not at the track that often and kind of want a lower stall on the street. I mean the 4,000 is great, but a bit too tall for me for everyday driving and bursts of speed.
Yank has (2) specficied nitrous converters, but who knows?
-Might also get Hardended output shaft while it is out.
Thanks
Bandit
Which one and why?
Thanks
Bandit
[SIZE=2]RPM Transmissions is a vendor in Indiana that builds a lot of trannys and all love them. 11.42 at 122.58 MPH was NA.
RPM does good work and did most of my work, heads/cam/TC/gears/etc etc etc
I ran 11.10 at 124MPH on the bottle in 90 degree heat, haven't sprayed in the cool air yet. That was one of the few times I sprayed.
I should be in the 10's with a beefed up tranny spraying out of the hole and THROUGH the shifts which I don't do now!
Here are the 2 Converters for Nitrous from YANK
Nitrous/Blower Converters:
PRO YANK 3400 EXTREME 4L60E/4L65E
258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3400 stall, 2.70 STR
OR
PRO YANK 3600 EXTREME 4L60E/4L65E
258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3600 stall, 2.30 STR
OR
Originally Posted by 2001 Red Coupe Bandit
ttt
Thanks guys
Sould I get a new converter??????? Like an SS3600 or the nitrous 3600 equivalent
OR
Upgrade to Bigger Gears, like 3.73's for my existing 3.42's?
Thanks guys
OR
Jim C.
PS-It runs 10.97@125 with a soft 1.62 60-ft. time as I am still tuning the progressive controller.
I going to be switching from 3.90's to 3.42's along with switching from my PT4000 to the PY3600. I'll post results once the PT4000 sells and I can get the car back together
JEFF
JEFF
Thanks I am interested what I should do??
Those Nitrous converters are $895 and the YankSS4000 that I paid high dollar for, went down quite a bit as Yank lowered all their prices and sell direct now.
Thanks Guys
Thanks Guys
I'm running a Yank SS4000E, and it's taken everything I can throw at it, workin great with a 300 shot, will see how she does when I change my nitrous setup and up the jets!
