Switched 12v source--how many accessories?
Well, by the time I'm done, I'll have an arming switch, bottle heater, bottle opener, and RPM window switch that will all need a switched 12v power source. My question is....can I run them all off of one source, or do I need to find multiple wires to tap in to?
-Jason
-Jason
-Jason
-Jason
im not sure he was asking bout the relays he was asking for the 12 volt source . . like the on and off switch . .i was wondering the same thing i dont want to over load my radio fuse ..
Closed ex-Sponsor Account
-Jason
-Jason
What you have listed will not pull any more than 5 amps and that is only if all things were hit at the same time.
Hi amp goes straight to battery, do not even attemp to find a wire inside the car for the solenoids or heater pad.
Ricky
Originally Posted by NXRICKY
Trick question depends on the wire you are tapping into. You can run all your low amp control stuff off one wire. What I mean is any switch that is running to control a relay is low amp.
Ricky
Ricky
I am running the entire control panel from one switched source in the C-5.
Dry to a relay
Wet to a relay
Heater to a relay
Purge to the noid
Opener to the opener
Factory Yellow wire in the Pigtail in the passenger footwell.
No problems.
Dry to a relay
Wet to a relay
Heater to a relay
Purge to the noid
No problems.
Dry to a relay
Wet to a relay
Heater to a relay
Purge to the noid
No problems.
Dry to a relay
Wet to a relay
Heater to a relay
Purge to the noid
No problems.
Robert
Originally Posted by Robert56
Me too (7-relays, and lap top off the same wire. All the 12v keyed source does is trigger the relay contact inside said relay, and dosn't require but a few milla amps to do so. So , like Ricky said, but I think it's even lower than 5 amps. just make sure your triggering relays only and not the direct source of power for any of your stuff you mentioned.
Robert
Robert
Ricky
Do most mechanical bottle openers operate without a relay? Should I go ahead and tap in to an alternate 12v switched source for that?
I also have a BMN window switch that operates on a 12v source....that shouldn't draw much current, right?
Sorry...my electrical knowledge is very limited!
I found a nice 12V switched source on the fuse block, its actually a single female spaid port. I used a male spaid connector and put a single 10A fuse inline and I run my bottle heater switch, line lock switch, arm switch, purge switch, & Timing Tuner all off it with no issues.
