Is the TR6 cold enough for 600 on spray?
Old Aug 14, 2006 | 05:31 PM
jermstyle's Avatar
Default Is the TR6 cold enough for 600 on spray?
I’m running a little over 11:1 compression and should push a tad over 600 on spray – will the TR6 be cold enough or should I move up to a colder plug?
Also, are the Iridium’s recommended for this setup?
Thanks!
Old Aug 14, 2006 | 05:34 PM
xaon's Avatar
600rwhp total, TR6 should be fine.
Old Aug 14, 2006 | 05:49 PM
iamsickofitall's Avatar
i think that would be on the border of going a step colder with a higher compression motor, but you should still be ok
Old Aug 14, 2006 | 06:36 PM
sprydncamd ta's Avatar
i run the 7 series at 675 hp and have no noticable all motor difference
Old Aug 14, 2006 | 07:18 PM
CAT3's Avatar
Restricted User
I ran TR6's gapped at .030" pulling 602rwhp on only 16* timing and richer than the WB low limit of 10:1, pulled plugs, no issues at all. And yes I also ran them on the track before.
Old Aug 14, 2006 | 08:05 PM
SSwanner's Avatar
mine did 540 through a slipping th400 on a tr6's gapped at like .033", has been fine with 11.3:1c/r and like 11.3:1 a/f ratio
Old Aug 15, 2006 | 07:47 AM
jermstyle's Avatar
Thanks for the info - no comments on the Iridium’s, so I'll leave those alone.
I'm going to run the TR6 I guess, I might order a set of seven's though to test out.
Old Aug 18, 2006 | 10:58 PM
TJ's Avatar
TJ
i have good luck with an autolite 103.
tr6 wont run well for me.
sometimes it wants to spit and sputter.
Old Aug 19, 2006 | 11:19 AM
badls1's Avatar
Thanks!
made over 700rwhp with tr6 spark plugs on F&L race fuel 113 octane
