do i have enough fuel
Old Aug 19, 2006 | 02:49 PM
ls1marine's Avatar
Default do i have enough fuel
i just bought my nitrous works 150 wet shot....so here is my question with my tr230/224 cam can i still spray the 150 wet shot on my stock pump and injectors
Old Aug 19, 2006 | 02:58 PM
CAT3's Avatar
Restricted User
Not recommended unless you have access to some tuning or dyno with wideband. All too often the stock pump wont handle the full 150shot once you've done bolt-on, HC etc.. you migh squeeze by with a hotwire kit.
Old Aug 19, 2006 | 03:07 PM
ls1marine's Avatar
"hotwire kit" not sure what that is and what about just a 100 shot
Old Aug 19, 2006 | 07:03 PM
ls1marine's Avatar
any more help guys
Old Aug 19, 2006 | 07:28 PM
oange ss's Avatar
75 would be the biggest i would run in your situation
Old Aug 19, 2006 | 11:46 PM
ls1marine's Avatar
thanks man
Old Aug 19, 2006 | 11:53 PM
BOTTLEFEDLS1Z's Avatar
Thunder is having 10% of racetronix stuff right now till the end of the month. That would be fine..
Old Aug 20, 2006 | 12:04 AM
ls1marine's Avatar
wait what does that mean did i miss something
Old Aug 20, 2006 | 02:28 AM
oange ss's Avatar
fuel pump kits
Old Aug 20, 2006 | 02:59 AM
chris2000ss's Avatar
I would definetly get a new fuel pump. (racetronix)
Old Aug 20, 2006 | 09:50 AM
Matt@HSW's Avatar
If you can watch your fuel pressure when you spray see if you loose a few psi. It you do I'd go with a new pump, like a Racetronix kit.
Matt
Old Aug 20, 2006 | 02:46 PM
ls1marine's Avatar
Matt
thanks man
Old Aug 20, 2006 | 04:39 PM
Screamin_Z's Avatar
I have the Racetronix fuel pump kit and I love it. very easy to install, the biggest pain in the *** was droppin the tank which wasn't too bad. If u do buy this make sure u wear safty glasses when dropping the tank, there will be alot of dirt and lil rocks on top of the tank. HIGHLY RECOMENDED to buy a kit like this from one of the vendors. I bought mine from Matt at HSW
http://www.harrisspeedworks.com/shop...cat=330&page=1
Old Aug 20, 2006 | 06:47 PM
or you could just cut a trap door in the trunk like i'm doing...just my .02$
Old Aug 20, 2006 | 06:48 PM
also Thunder racing has the racetronix on sale for 10% off untill 8/31
