Sprayed for the first time..some questions.
Also i have BMN window switch all wired in..and im pretty confident its all wired correctly. We were just testing the nozzle to make sure it was spraying properly..and it would spray while the car was sitting in neutral not even started. Is this normal? Is there anyway besides spraying i can actually tell if the BMN switch is working properly? When i sprayed..i just rolled into it..then hammered it..not knowing it my BMN was working properly.
Not familiar with the BMN switch. Doesn't sound like it's working to me? I take it you already set the min RPM greater than 0? Maybe it didn't work right since it saw no tach signal, you think it wouldn't work at all without a tach signal though.
I'm thinking it has more to do with the shark nossle not spraying straight. Shouldn't it be angled toward the center of the intake opening?
yes, it should be spraying straight into the center of the intake so that it doesnt spray on the intake and puddle and pool... that way you get proper atomization, if it was hitting the intake and puddling up then that coudl be the backfires every time it was pulling a drop of it out of the intake?
once i put it on the dyno the other day i found out it as far from rich, 15.1 A/F.
my car was popping becuase of how lean it was running.
if i were you i would strap a fuel pressure gauge to the windshield and see how that goes before spraying it anymroe.
