Do you have to use a blow down tube?
No, a blow down tube is only required to meet NHRA/IHRA regulations for safety but they create these rules for a reason and I know I wouldn't want a bottle de pressurizing into the car.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by _JB_
Some tracks will let you race, some won't.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
If you are not going to a strict tech track then it is really up to you. I can tell you this, while they are designed to help minimize risk there are WAY more people not using them by in large. Having said that I would never tell you not to err on the side of caution. Having one will add to the overall safety of both your vehicle and yourself but I don't personally use them unless I were to run at a track that required them. Hope this helps and good luck to you.
Jim C.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Jim C.
A blowdown tube is only required if your bottle is mounted inside the passenger compartment. You do not need one if your bottle is mounted in the trunk (from my understanding..correct me if I am wrong).
You do need a blow off valve either way.
Because this is LS1TECH I made the assumption in my first post that he was referring to a blow down tube in an f-body, Vette or in the cab of a truck.
If you don't want to buy a blow down kit, a length of braided line and a 90* AN fitting works well too.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
That is correct.
If you don't want to buy a blow down kit, a length of braided line and a 90* AN fitting works well too.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
The blow-off cap contains the pressure releif disc which bursts at 3000psi. The blowdown tube is what attaches to the blow-off cap. In the case of the pressure releif risc rupturing, the blowdown tube's purpose is to guide the nitrous outside of the vehicle.
Now, like I said earlier, if the bottle is mounted inside the passenger compartment, a blowdown tube is required by NHRA. If the bottle is mounted in the trunk of the vehicle, a blowdown tube is not required but a blow-off cap is.
I hope this clears things up.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
