WOT switch
Old Sep 27, 2006 | 12:30 AM
BigDB's Avatar
Default WOT switch
I broke mine trying to get it to fit near the TB. Would it be in better intrest to use a electric one that senses voltage of the TPS or use a mechanical one? I cant for the life of me get the braket to clear my BBk TB. ALso what is the TPS voltage range? 0-5v?
Old Sep 27, 2006 | 06:25 AM
charlie c5's Avatar
You could use a TPS switch, and or you could mount your micro switch down on the floor board at the gas peddle.
Old Sep 27, 2006 | 06:55 AM
04Mark's Avatar
[QUOTE=charlie c5you could mount your micro switch down on the floor board at the gas peddle.[/QUOTE]
+1
Thats where I have mine!
Old Sep 27, 2006 | 10:18 AM
BigDB's Avatar
iv seen the pic in the wiring sticky of them on the floor, seems like the bracket would ned to be bent in a weird way to get it to fit. But ill try it since micro switches are alot cheaper
Old Sep 27, 2006 | 10:29 AM
BADSZ28's Avatar
I have mine on the floor under the peddle. I don't have a pic, but once you take off the plastic part under the peddle you can figure out how to mount it.
Old Sep 27, 2006 | 11:00 AM
SS SLP2's Avatar
https://ls1tech.com/forums/showthrea...ght=wot+switch
go to post # 8
code4 suggestion worked great for me
thank you code4
Johnny
Old Sep 27, 2006 | 02:18 PM
BigDB's Avatar
ya I posted that thread. But i have a BBK TB and it uses a braket to extend the throttle cable bracket forward. Since the bracket is bolted to the original position it blocks where I can mount the WOT switch. I would have to run the cable thru the mounting tabs hole so ima mount it on the floor
Old Sep 28, 2006 | 11:05 AM
01_ram-air's Avatar
Mine is mounted on the floor and haven't had a single problem with it.
