Stand alone fuel system FS!!!
Old Sep 28, 2006 | 08:43 AM
Noyzee's Avatar
8 second mod
Thumbs up Stand alone fuel system FS!!!
Its a 1 gal fuel cell, all fittings, roll over valve,caps, ground ect ect.
holly 14 psi pump
straps for cell, mounting bracket for pump.
-6an braded lines to regulator.
Holly, polished regulator with all fittings needed
this setup takes the place of the batery and over flow.
i mounted a nice lightweight alum can for an overflow, and put it in the spare tire compartment. looks good, saves weight.
anyway, this system requires very little cutting ect.
small cuts to make cell fit unless you mount it high. i cut mine so it sits nice and low, looks nicer IMO
horn would need to be moved a few inches or removed.
the way its set up is the pump mounts right to the existing threaded hole for the horns, then 2 straps on the cell hold the rest. its solid!!!!
i can make the line from regulator to what ever, (y block, noids ect, just need to know how long.
the regulator comes with line that will alow you to mount on the wheel well, or front rad suport what ever you like better.
Make a reasonable offer on this. It cost about 600 to build with all the fittings ect!
you can see the cell in this pic, but its set up for dual stage (which i can also sell it like that if you want, regulators mount on the pass side head to existing holes
Not a good pic, but it shows how low i have it sitting, looks very clean!!!!!!
this pic is last year with 1 stage set up.
you can see the regulator under the red one. the system would come with a new one tho. you can see the caps, fittings, down tube ect in this pic also.
Old Sep 29, 2006 | 08:10 AM
Noyzee's Avatar
8 second mod
Bump up again!
no reasonable offer refused!
Old Sep 30, 2006 | 09:07 AM
NitrousDirect's Avatar
TTT for noyzee!
Old Sep 30, 2006 | 11:45 AM
Noyzee's Avatar
8 second mod
thanks
Old Sep 30, 2006 | 04:14 PM
thechef's Avatar
Moderator
i bid $1.00
but seriously TTT fior ya
Old Sep 30, 2006 | 06:10 PM
Speed Density's Avatar
hashtagBMW
I will be in touch Noyzee.
Tony.
Old Sep 30, 2006 | 09:42 PM
1MEANGTO's Avatar
how much
Old Oct 1, 2006 | 09:51 AM
Noyzee's Avatar
8 second mod
Speed, let me know.
1 mean, pm sent
Old Oct 3, 2006 | 10:50 AM
Noyzee's Avatar
8 second mod
compleat setup.
$350 plus shipping
