90/90 and TNT power ring
Old Oct 7, 2006 | 12:17 PM
99WS7's Avatar
Default 90/90 and TNT power ring
OK so I just got my 90/90 set up and I also have a TNT F1 kit waiting to go on. What are you guys doing to install your kit. The power ring sit against the TB witch it will fit on the stock one, but the fast one is 90 so I was thinking a simple rubber bellow splice will work so the power ring on the fast 90 TB. I just wanted to see how others were hooking there set up.
Old Oct 7, 2006 | 01:07 PM
beardWS6's Avatar
I went to a 90mm Nitrous plate from Dave. Love it!
Old Nov 19, 2006 | 10:29 PM
Jimmyz's Avatar
Question
Whats the part # on the 90mm plate please?
Jim
Old Nov 20, 2006 | 09:12 AM
Nitro Dave's Nitrous Outlet's Avatar
Here you go.
http://www.nitrousoutlet.com/catalog...product_id=993
Old Nov 20, 2006 | 10:52 AM
TRMIN8R's Avatar
I called TNT and they sent me a 90mm power ring It fits a lot better than the stock one.
Old Nov 20, 2006 | 11:00 AM
02SOMWS6's Avatar
I gave a machine shop my ring and 90mm ring and they machined it down to fit
Old Nov 20, 2006 | 06:00 PM
JoeyGC5's Avatar
3 minutes with a file on the throttle body lip and the TNT ring fits all snug like a bug.
Old Nov 20, 2006 | 06:04 PM
JoeyAnderson's Avatar
I found the same to be true on my Nick Williams.
Old Nov 20, 2006 | 08:47 PM
JoeyGC5's Avatar
Old Nov 20, 2006 | 09:33 PM
98Aggie's Avatar
Moderator
With my FAST 90mm I took a piece of Al flat bar and wraped it around the silicone hose hose and rivited. I then drilled through the Al and hose and used a 10mm tap.
When I installed the NW 90 I machined the TNT power ring I think .03" over and it fit tight.
