View Poll Results: Size of Shot on Stock Bottom End for LSx Motors
75
8
2.35%
100
64
18.82%
125
31
9.12%
150
131
38.53%
175+
106
31.18%
Voters: 340. You may not vote on this poll
Stock Bottom End LSx guys...
Old 11-16-2006, 01:16 PM
  #41
Robert56's Avatar
Originally Posted by 00Vette
I'm spraying 150 shot on my stock bottom end, but I'm making around 550hp on spray. So I think I'm kinda pushing the limits of the stock bottom end.
I want to go for 600rwhp on a stock bottom end and hope it'll hold up. I think that much power on the stock piston/conecting rods is asking for disaster.
You and I both. let's hit the dyno this fall and go for the 600+rwhp.
Robert
Old 11-17-2006, 06:41 AM
  #42
smokin00ss's Avatar
Right now Iam spraying 125 wet, but actually getting 132rwhp with a stock fuel system. Plus I have a cam on top of it.
Old 11-19-2006, 03:27 PM
  #43
Nitro Dave's Nitrous Outlet's Avatar
A 150 shot is your safety point on what the motor is desighned to handle. As you can see there are people spraying more. Some hold up and some do not..
Dave
Old 11-19-2006, 08:42 PM
  #44
383LQ4SS's Avatar
We have done 680 rwhp with a stock bottom. Dual stage dry/wet ~275 shot
It finally popped when the owner was trying to chase down a very fast Z06 to 200 mph in 5th gear spraying away without enough octane in the tank to cover detonation. And even then the bottom end was intact. It had burnt a valve and part of the cylinder head.
Old 11-20-2006, 08:36 AM
  #45
02SOMWS6's Avatar
If you have a standalone fuel system to support the nitrous and a good tune I wonder how much the bottom end will handle. Every case that I have heard of were there was a problem was because of lack of fuel.
Old 11-21-2006, 03:17 AM
  #46
Hi Volume's Avatar
hahaha thats badass! Of course one of the nitrous rules is to NOT spray in 5th!!! But what fun is that!
Old 11-21-2006, 03:43 PM
  #47
00Vette's Avatar
Robert
I'd love too! But I need to get my clutch fixed first...........then I can install/finish my gauges and install my wideband........then I'll be able to tune the 200hp shot more accurately.
Old 11-24-2006, 09:36 AM
  #48
5LETR's Avatar
My last LS1 had a small cam 224/224 and a 125 dry shot. I ran upwards of 30, 15# bottles through it. No problems.
Old 11-24-2006, 05:53 PM
  #49
_JB_'s Avatar
Had Harris Speed Works with Nitrous Daves plate with 150 shot.
Old 11-29-2006, 11:44 AM
  #50
1999TransamWs6's Avatar
250 here, she made 667 through a th-400
Old 12-08-2006, 07:25 AM
  #51
02 BLK WS6's Avatar
125 dry for now. Thinking of doing a 2 stage 100 off the line and another 75-100 after I hit 2nd gear.................... 1st stage will stay dry 2nd will be wet stand alone, or vice versa......
Old 12-08-2006, 11:43 AM
  #52
turbo'd stang's Avatar
I'm spraying a 250 shot, cam only, makes 650rw. I'm using a carb intake with a carb plate. It makes some good power. Car makes 350rw on motor, so a 300rw gain through a PG is pretty good.
Old 12-08-2006, 08:21 PM
  #53
Wilkenstein's Avatar
Christ, these engines are so much stronger than I thought!
I have a question though. I have an untuned bolt-on car that I would like to get tuned. I would also like to run 150 shot with Dave's plate. Should I wait untill I get the kit before tuning? I only ask because it will probably be quite a few months before going on the juice. M6 car if it matters and I will be running FPSS, window switch and bottle warmer right off the bat. Thanks
Old 12-09-2006, 11:43 AM
  #54
Reject's Avatar
dont do the 150!!! wait to pull some timing out first, i burned all my plugs like that owell at least i got one run out of them
Old 12-12-2006, 12:30 AM
  #55
JonSS_Tex's Avatar
Dave
Hey man whats up...I have a tnt f1 kit and have passed about 4 bottles through it with 120k miles on it. this wkend i installed the wal.255 fuel pump and on tuesday i am dropping it off at MTI for a nitrous tune....should I be alright with that many miles on it?
Old 12-13-2006, 08:15 PM
  #56
Lythropus's Avatar
I had 170 shot dual stage (dry/wet) but only had 3 bottles through it. This was stock timing and stock fuel system. I later upgraded the fuel system and added a stand-alone for the second stage to go bigger but didn't get a chance to use it before someone hit my car. It was only in my car for a day then I had to take everything out before the claims adjuster came to look at it.
Old 12-15-2006, 09:47 AM
  #57
ddnspider's Avatar
Received 1,739 Likes on 1,299 Posts
had a baby cam and a 125 shot.....went through a bottle in a day,sprayed on launch,etc no issues
Old 12-15-2006, 07:56 PM
  #58
BBBBadSS's Avatar
150 shot. Didn't even use a full bottle this last summer.
Old 12-20-2006, 12:08 PM
  #59
01black's Avatar
100 for now with stock fuel pump...but will bump to 150-175
Old 12-22-2006, 12:29 AM
  #60
v8juice's Avatar
About 120 for 2 years on the Charger,car is one owner with 32000 miles and I use it when I need it which is kinda rare around here.
