Help an ignorant man here...
I am just looking for an efficient and safe setup to make my car run 120-124 traps in the 1/4. Either way is perfectly ok with me as long as it gets the job done safe and effectively.
So... what you guys think? Wet or Dry? Direct Port is out of the question due to financial reasons. haha
Dave
When would a dry setup be preferred over a wet setup? Upgrading the fuel system doesn't concern me to much as I was planning to do it anyway just incase.
I plan to spray it a lot so I am going to do take every safety measure I can to insure the motor.
Different set ups fit different peoples needs. I have used both wet and dry. I just prefer a wet system.
For example,
With dry you are relying on the fuel injectors to support the extra needed fuel.
Because of this you may need to upgrade injectors to support the fuel demand.
You will have to do computer tunning in order to change air fuel and timming properly.
With Wet.
You will not have to worry about injectors. You can adjust airfuel by simply changing the fuel jet out. Since you can adjust timming with a timming tunner you can make changes with out needing any computer tunning.
With Dry.
The bottle pressure is not as critical as with a wet system. If you have low bottle pressure with a dry system you will simply just not make any hp gains. With a wet system if you have low bottle pressure you will go rich and loose HP.
Both systems will work when used correctly. You just need to pic whats suites your needs the best. Just because one set up is good for one guy does not mean it is for the next guy.
Dave
I like wet myself b/c a wet shot will usually hit quite a bit harder.
Most people will say that a dry kit is generally safer.
The key to a safe kit (wet or dry) is getting all the add on equipment that will save your motor if something out of the ordinary happens.
Now... I am guessing that a Dry shot distributes the Nitrous better? Doesn't a Dry shot have more nozzles distributed next to each injector?
I know that's true with LT1s because the Intake runners are real short so cyliners 1 and 8 get a little saturated with nitrous. The reasoning might be wrong but I know that's what happens. haha
Why would a Wet Shot "hit harder" then a Dry shot? Isn't it generally doing the samething?
I will be taking every safely measure possible. Nitrous cutoff switch, WOT Switch, Window Switch, etc... and whatever else there is. haha
Here is a nice write up concerning wet vs dry. Like Dave said, some are more suited to go with wet, whereas, some are more suited to go with dry. Myself I am a dry guy and love the inherent safety of the dry, try to find someone who has hurt there motor with a properly set-up dry hit, this can not be said for wet hits. Now don't get me wrong, wet hits are fine and safer than ever before, so the choice is yours based upon the needs/facts.
Colonels Tech Files
Robert
Either setup works great though.
Here's another senerio, on your wet hit, what if your nitrous noid sticks open (I have had two do this), well your in big trouble again cause your fuel noid just closed by the WS, whereas your dry kit will continue to add fuel when nitrous noid stick open. You'll also know when your n2o sticks open on dry cause the rpms shoot up, ask me how I know.
There are many other scenerios concerning failures where the wet kit will cause destruction and the dry will not.
The misunderstandings concerning dry hits never cease to amaze me. They are the future of FI cars, mark my word.
Robert
Robert
Robert
I don't misunderstand anything about the dry kit I have helped two friends install them and did much research on them before I bought my wet kit. Oh and my old roomate has a 2000 Z28 that the MAF failed on at the end of July, it does happen.
