Maybe done for the season
We had a track rental at MIR monday and i put it on the bumper and drug it a bit it came down hard and looks like i lost the oil pan and bent my kooks. paf oh **** bars helped me some it could have been worse. the oil cought fire and purned the plastic cowl and some of the brake stuff. im going out now to pull it apart and look at the damage.
anyone else put a glide on the bumper? we had a 30" tire and a 1.8 first gear was only the 225 shot. damn car came up fast. looks like im goan switch te stages next time 150 first 225 2nd. i never got to try the 2nd stage this was on the shake down run.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I hooked a 200 shot on a 1.80 glide with front end limiters keepin it down, I stood it on the bumper with a 150 shot and no limiters at 5000 off the brake. Try coming down to 3600 (what works for me) and some limiters. Cut a 1.28 60 liftin a foot off the ground on a 29.5 x 10.5 phoniex with a 175 shot off the brake at 3600, ran 9.13 @ 148.
I have seven adjustments on mine (competition eng limiters) and the 1.28 was with them set in the middle so if the front end was to come up too much i can always adjust them up so it keeps more weight over the front. Easy to tune the car with for different tracks/track preps. As long as the rear tires dont unload your better off keeping the front tires only a foot off of the ground. Remember energy used to go up is wasted energy that could be going foward.
8 second mod
i run the glide with a 1.8
i went my 9.0 with a 1.31 60 foot, and didnt even lift the tires.
no travle limiters
http://1960belair.8m.com/Videos/Noyzee.wmv
not to say i wont next year, im going to try to set my car up for big wheelies to make it fun. i will be running a 9.5 class, so i need somthing to make it interesting.
but its all in the suspention and tuneup.
that sucks tho, braking **** sucks big time.
no travle limiters
8 second mod
Originally Posted by ATVracr
Noyzee, you using a Progressor?
however even with 300 right out of the hole, i didnt have big wheelies.
this was a tad higher on video, but no bumper.
MIR event, 300 out of the hole, 1.32 60'
its all in the suspention tune up.
as you can tell, no limiters in the front, notice the sag
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![](http://img.photobucket.com/albums/v357/Noyzee/Noyzee%20car/454388981Xvypys_ph.jpg)
8 second mod
So whats the susp. tune up consist of ?
front shock.
also weight transfer is very importain. thats why i hung my battery back up front and out of the trunk. corner weights ect are importain.
there is alot to it
8 second mod
Originally Posted by ShiznityZ28
we got the 60's down. we ran the car with the shocks on 6-7 in the back and 7 up front. The car just gets outa the hole good always has.
i know it happens for sure, and in these lsx cars it is very easy. little softer out back, and it may have been fine. those clicks make a big *** differance.
the fronts on 5, rears on 6, would probably help if your weight is right.
Originally Posted by Noyzee
getting out of the hole good consists of not riding the bumper and smashing **** up.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
thanks for the help though.
8 second mod
how would softer fronts help.
if you loosen everything up and it hooks its going on the bumper easyer.
you went on the bumper, i didnt, i have run just as fast 60'
maybe you should take my tips for what there worth instead of bustin *****. but thats cool either way, its your money getting smashed.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
8 second mod
Forgive me if I'm wrong but everytime I loosen the fronts the car wheelies more
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
tight up front less spring. my bad. its been a while since i had to adjust any suspention
