Check this out! NEW Nitrous Product @ SEMA
#61
1 Post
Originally Posted by Bad Habit Bird
Outside temp will not effect the bottle pressure of the nitrogen like it does the nitrous. Whatever you set the regulator at is what your nitrous bottle pressure will stay at. That is what is so nice about this type of a setup
#63
Originally Posted by cyipher
Wrong
Care to elaborate?
I guess I should have been more clear in what I said as well. Basically the nitrogen tank will have enough pressure to bump the nitrous tank to where it needs to be even in cold weather.
#64
You still need a guage and dont let this fool you your bottle pressure can still rise too high in the event the bottle becomes warm on a hot day.... 1500 psi and boom to the burst disk or boom to your motor cause you went lean
#65
Originally Posted by SmaknaSS
I wonder if someone could put a bleed off valve on top of the Nitrous bottle to bleed off the extra Nitrogen if the Nitrous bottle pressure gets to high? Since the Nitrous is at the bottom of the bottle and the nitrogen is at the top ( I think)it seems someone might be able to bleed off the extra pressure without letting out the Nitrous Oxide? Just a thought.
#66
possibly a fitting with a purge solenoid and line connecting it to outside the car?
P.S. maybe the pressure regulator from the Nitrogen bottle already takes care of that function?
#67
The blow off discs are usally 3000 psi. A correctly chosen nitrogen bottle will have the size and pressure so that even if the regulator fails with both bottles fully serviced it should not reach 3000 psi. Dont forget the pressures would equalize in that scenario. A small bottle with 4000 psi and a large bottle with 950 would probably equalize around 2000 psi (dependng on nitrogen bottle size of course)
I used to use a 15 lb nitrogen bottle with 2500 psi and a 15 lb nitrous with whatever the ambient pressure was after servicing..usually 900 psi or so. If there was a fialure and the pressure equalized...it would get to around 1600. No biggie at all.
And yes...once there is nitrogen in the nitrous tank to maintain pressure...you can bleed off excess pressure without releasing much N20 at all. I used to just turn my bottle upside down and crack the valve. Only nitrogen would come out...but as soon as you turned it over...lookout! Here comes the juice.
#68
1 Post
Care to elaborate?
its not a matter of cold weather but a matter of hot. cold no problem even if you run out of nitrogen. in hot weather your tank pressure can get too high if you pressurized the nitrous when it was cold.
nitrous expands and contracts nitrogen doesnt.
#70
Al, why not just put a ball valve (like was suggested) in the side of the n20 tank valve, then you just crack it to bleed off excess nitrogen pressure?
Robert
#71
When I said "Outside temp will not effect the bottle pressure of the nitrogen like it does the nitrous. Whatever you set the regulator at is what your nitrous bottle pressure will stay at." I was talking about the fact that nitrogen doesn't expand and contract like nitrous and it doesn't matter if it is cold or hot outside when you turn on the system, you will have the correct bottle pressure in the nitrous bottle at that time. Now if you turned on the system to pressurize the bottle on a cold day then it gets hot, of course the nitrous bottle pressure will go up.
I'm really glad Al made his way into this thread, I was hoping he would
Robert - Sorry, I didn't realize you were talking about pressurizing the bottle on a cold day, keeping it at that pressure, and using it on a hot day, in which case, yes, the bottle pressure would rise. You could always do like Al said and bleed off some of the nitrogen at that point.
#72
Robert...you could put a valve in the neck no problem....as long as you have a spot for it. Hell...you could put a solinoid in there and have a purge for your nitrogen pressure. Hell if you really wanted to you could put a pressure switch so that it purges automatically anytime the pressure is over what you set it.
When I had the NX Maximizer II I had it controlling my nitrogen system. A pressure sensor (not switch) went into the neck of my nitrous bottle...and it would open the Dedenbear 3000 PSI noid anytime pressure was below 1050. It would close just over 1050. The MaxII also has provisions for auto purge. You could hook up another noid and have it purge nitrogen right off you bottle neck at say 1100. Talk about fully automatic. Then of course you still need a regular purge to get the nitrous to the noid.
Of course you can do the same thing with two dynotune pressure switches. One to open the Dedenbear 3000 psi nitrogen noid at your set pressure of say 1000 psi. And one to bleed of nitrogen head pressure at say...1100 psi. You could have them both off a Tee right out of the neck. Then you need one more port for the noid.
When you go nitrogen...and have all these high pressure noids and switches there are a million ways to do stuff.
BTW I am more a fan of noid/pressure switch combo that regulator myself....as you can see. A regulator will have a flow rating...that flow rating may keep up with nitrogen demand to maintain perfect pressure of a 150 shot. But will it keep up with the demand of a 300 shot? 400 shot? Who knows. A 3000 psi noid/pressure switch setup...you can just add another noid in parallel if you need more flow. But the Dedenbear C02 noid PN 302ABSOV was easliy keeping pace with my 300 shot
Having said that though...I think this product kicks *** and its head and shoulders above a bottle heater. I have no idea what the flow rate of the regulator is but im sure it will work for 90% of the avg nitrous user perfectly.
Of course you could do the same thing with
#73
1 Post
#75
7 Second Club
It may have been covered but why don't you set the pressure to 1100 or whatever and just turn the system on right before you use it. We leave our bottle closed until we get ready to do our burnout, turn all the systems on and open the bottle is the last thing we do.
Phil
Phil
#76
Phil
Phil
Robert
#77
Originally Posted by Robert56@NitrousDirect
The problem with your scenerio, at least with wet hits, is, the variable tempture day to day, week to week. whats going to happen when you have your reg pressure set to a cold day, then the next day it's hotter or vs verse.
Just no stability in the final a/f unless you have your bottle at the same temp each time, and thus the need for still a bottle heater. Now a dry hit you would be fine a/f wise, but power differences would still be all over the place.
Here's my 30lb cure for bottle pressure drop.
Robert
Robert
hummmmm looks like there is room for another 15lbs worth of anti-preusre drop there!!
a quickquesion, i have been paint balling and the guys over here use Co2 i think. the probelm with these pushers is what happens when the nitrogen bottle gets cold????
thanks Chris.
#78
thanks Chris.
thanks Chris.
#79
1 Post
thanks Chris.
thanks Chris.
#80
cyipher, sorry but C2o cant be a liqued, its one of thoes gasses (can't remeber the f*cking term now) that can onlt be in gas or solid state!
Bad Habit Bird, does it really??????? what i was trying to say was does the Nitgrogen bottle sufffer from preusre drop like the N2O??
is there anything to stop you from using Co2???
thanks Chris.
thanks Chris.
