Problems w/ NX TPS WOT switch?
I got my test light out and ended up finding a bad connector for my battery-to-relay connection. Once I put this new connector on, the WOT switch stays on, even though it was adjusted properly before to only come on at WOT.
I checked the white wire right at the switch thinking it might be reading a higher voltage, thus triggering the switch. No dice....right at .5 v with the throttle closed.
The red wire from the activation switch had power, like it is supposed to with the key and the activation switch on.
The pink wire, which connects to the relay, has power too (which I suspected since the light on the switch was lit up)...even though it isn't supposed to until WOT.
I tried turning the adjustment screw too. No matter how much I turn it, the light will not go out. I figured as much since it was properly adjusted before all this started.
Any ideas? Anybody else have the same trouble? I think I'm gonna try using the microswitch I have this evening and ditch the TPS switch.
http://www.nitrousexpress.com/Instructions/tps.pdf
Ricky
Yeah...I might be there a while. Where/whom do I send it to? Anything special I need to include? Thanks for your help...it is much appreciated.
wichita falls Tx 76308
After one pull through a gear, i noticed it wasnt working....i went and checked the nx tsp switch and the light is on no matter how many turns. i think it must be fried but wtf?
This is bs!
