some easy nitrous questions
2-- These stupid NTP/flair fittings are $15 a pop and i need a bunch. I dont want to spend as much for fittings as i did for the kit alone. Can i use other fittings from a hardware store for like $0.50 ea.??
Dry kits are mounted before the MAF. Since they do not inject fuel, the N2O crossing the MAF is read as additional air. The MAF tells the PCM to feed more fuel. Since the wet kit injects fuel on its own so... You can see where this is going.
I want to mount my wet nozzle behind the MAF inbetween the 2 hose clamps. But if you look further down the intake elbow, right before the TB on the lest side you can see my IAT. So if my nozzle is mounted AFTER the MAF and before the IAT, will i be ok??
