Bottle In Between Rear Seats ?
Old Jan 6, 2007 | 12:17 PM
rez0469's Avatar
this is a stupid question but do you need a nitrous pressure gauge when the bottle is between the rear seats? I am not sure if my kit camw with a gauge or not that is why I am wondering
Old Jan 7, 2007 | 08:50 PM
nate-roth's Avatar
You still need at least the gauge mounted on the bottle. If you want you can still put in a pillar gauge, but you could just turn around and look at the bottle guage. They now have pressure tranducers that wire in-line with your bottle heater relay that will keep the bottle at a preset temp. Some kits come with bottle pressure gauges, some don't. A way to know the pressure either at the bottle or a remote gauge is considered mandatory in the nitrous world.
Old Jan 7, 2007 | 08:51 PM
nate-roth's Avatar
There also aren't any stupid questions about nitrous until you ask one after you toasted a motor. Ask before, learn and don't hurt your ride.
Old Jan 8, 2007 | 08:40 AM
BIG_MIKE2005's Avatar
Well, I'm gonna be swapping out my Autometer gauges for some digital Dyno tune to watch mine. I'm goin to go with Fuel Pressure, Nitrous Pressure & LC-1 wideband Air Fuel. I don't mind turning around if I'm in-out of the car & not tryin to drive, but while driving I would rather look at the pillar.
Old Sep 26, 2007 | 06:58 AM
JEB99TA's Avatar
Originally Posted by MOTRUBL
I just drilled a hole. I can plug it if I ever want to take it out.
That's what I did as well .... worked perfect with the bottle mounted on Nitro Dave's tunnel mount ... just drilled a hole right into the tunnel with a standby rubber plug if the bottle is pout of the car. The NX blowdown tube was long enough to get the end of the tube about 1/4" - 1/2" into the tunnel and it clears the driveshaft easily.
