Any ideas on what this combo is "rated" at?
A friend hooked me up with a free nitrous kit.... big mistake
Its a compucar wet kit that came off a 5.0 - I ditched the compucar nozzle because the jets weren't even close to being right for my car and you cant find jets anywhere.
I bought a NOS nozzle and started with 61/30 pills, running the compucar tiny noids, the fogger is spraying behind the MAF, stock LS1 rail pressure, and around 900 psi of bottle pressure.
Any ideas to what this combo might put down (add) to the rear wheels?
AFR averaged at 11.59 (keep in mind the 42lb SVOs)
Thanks,
David
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Thanks,
David
Originally Posted by Nitro Dave's Nitrous Outlet
I would suggest a set of NX solenoids with carbon fiber cans.
Or the Nitrous Outlet solenoids with purge port design.
Both lifetime warrenty..
I like my solenoids big, strong and high flowing. Turn that little wimpy noid into a purge solenoid.
Dave
Dave
Do you have any idea to what my current combo might be rated at?
Thanks,
David
Im not a fan of the new NX carbon fibre noids.We bought a set and we ended up sending them back due to the inlet and outlet sizes not being what we were looking for at all. A local guy had some fail and Im not a believer in the lighter noid is any better. I liked the old NX ICEMAN noids though. I use the big Proflow noids now though good to 400 each. good luck man there is plenty of n2o knowledge on here and the sponsors are very helpfull.
So you guys think these solenoids are holding me back with my current jetting? I don't have a lot of nitrous experience and I don't know what to expect. There is definitely a SOTP increase but nothing out of control.
What is a safe WOT AFR I should shoot for?
I'm currently running TR55s gapped at .55 - I will be switching to TR6s next week - gapped at .35?
Thanks for all of your help!
