How hard can we really push the LSX!!!
I think Shiz is shooting for 400 shot and I'm going at least 300.
As long as the tune up is good I think 450-500 would be doable with the right heads, studs and gaskets.
if that didnt happen who knows.
i say we start a collection. everyone pay pals to an independendent person. like 20 bucks. hope it adds up to 10k or so, you spray the ***** off your car see what it takes, then rebuild it on us!
When I get everything situated, i'm gonna be tryin 400, hopefully she holds!!!
I was breaking up the hit on the motor by only .1 seconds (250 wet/100 dry and also tried 200 wet/150 dry and burned the same plug again) and running two 15 lb bottles to keep the pressure up and she was running pretty rich in the 10's on the afr with 18 degrees timing.
And i've run a 300 shot through her for at least 30 passes i'd say w/o any problems, but wanted to go faster which is why I tried the 350 and found the distribution problem and now goin to the fogger.
I'm planning on using a progressive with the new setup and gonna come out of the hole @ 50% and ramp to 100% within the 60' to try and help keep the front end down some.
So far i've been lucky and haven't had a problem with lifting the heads (knocks on wood), but i'm curious what kind of compression the guys that are having the problems lifting the heads are running, wondering if my fairly low compression is saving me being @ only 11.3:1.
Mike
All it takes is one noid to stick, a bad plug or something in a fuel jet or something and you can have a problem, big problem at that level. Brad's a perfect example.. injector went bad, no way of knowing that is gonna happen, and look at what happened.
