getting ready to buy....
Dry kit you should look at a window switch at the minimum to compliment the setup.
Wet kit you're going to want atleast a window switch and FPSS (fuel pressure safety switch)
The main thing you need to think about is whether you want to upgrade the fuel pump (wet shots) or the injectors (dry shots) for bigger shots down the line.
this was one of the kits i was looking at
http://www.harrisspeedworks.com/shop...cat=365&page=1
If you plan on running in cooler weather you'll need a bottle heater also. During warmer weather its a little easier to get your PSI where you need it, but a heater still helps for keeping pressure steady and giving you more consistant runs.
http://www.harrisspeedworks.com/shop...cat=308&page=1
DynoTune
Nitrous Outlet
HSW
Nitrous Direct
I would suggest their base dry kits and then add a window switch, bottle heater, purge, and new TR6 plugs to your order. Other things to consider is soleniod brackets if your looking for a clean show style install, as well as control panels.
One thing that I've been told on this board is that a tune would be a wise idea, especially if you've already had your car tuned NA.
