Has anyone tried this (2 heaters)
Old Feb 4, 2007 | 10:18 PM
dame's Avatar
Default Has anyone tried this (2 heaters)
Has anyone tried using 2 bottle warmers (15 lb bottle of course)
forgive the newbie type question.... but i cant see any disadvantages to doing this.
IF in fact there aren't any drawbacks from doing this: Would it be necessary to install a second thermostat (I'd be using (2) dynotune bottle warmers with adjustable thermostats)
or would the one thats already on there suffice?
Old Feb 4, 2007 | 11:40 PM
SScam68's Avatar
amp draw would be an issue, be careful
Old Feb 5, 2007 | 07:14 AM
NHRATA01's Avatar
Yeah, I think you'd want to run the wiring for each system individually - seperate heavy gauge wire running to a relay for each. Could probably have them share the pressure switch though.
You might kill your battery pretty quickly too though.
Old Feb 5, 2007 | 07:37 AM
SPLATT's Avatar
Draw +1. i say stick with a single pressure regulated heater.
Old Feb 5, 2007 | 08:04 AM
koolrayz's Avatar
I use 2 when its cold. You can use the pressure switch/thermostat to control 2 relay's instaed of one. as the others stated use 2 seperate wiring sytems for the heater (other than relay control) and watch your battery. I keep the jumper cables on the tow vehicle or keep the car running when using both.
Old Feb 5, 2007 | 08:16 AM
dame's Avatar
Originally Posted by koolrayz
I use 2 when its cold. I keep the car running when using both.
I could do that thanks.
Old Feb 5, 2007 | 08:18 AM
dame's Avatar
Did you notice a substantial decrease in wait time building pressure with 2 heaters instead of one?
Old Feb 5, 2007 | 12:12 PM
koolrayz's Avatar
yes seemed like it almost cut it in half although i never actaully timed it. I know when its really cold out here it can take 45 min with one blanket to heat a cold bottle. plus it really helps recovery time between passes if your spraying a large shot.
I should add that i have relocated my battery and have a large frame (29) deep cell battery that weighs a ton
Old Feb 5, 2007 | 12:21 PM
dame's Avatar
I have a yellow top optima FWIW (not relocated though, my bottle is in my spare tire well)
Old Feb 5, 2007 | 08:16 PM
Robert56's Avatar
I run two, but on two bottles. However, like stated battery can be effected. I had to replace my old batt cause anytime I had both heaters on, while car was running, the volts would drop to 11v. Charging system could not keep up with weak battery and the amp draw going to heaters, new batt cured this. I also run dedicated wiring system to each.
Robert
