traction control / nitrous arming wiring question
'99 vette
i want to arm my nitrous system when the traction control is off. or disable the system when it is on, however you want to look at it.
problem: TC is toggled on and off by a momentary break in continuity, not by voltage - no voltage.
does anyone know of a lead that is only on or off when traction control is on or off?
The problem for some is the later cars also have active handling, so toggling may not work as Todd has done? Don't you guys just have traction control on/off, my '97 had this, but the Z06 has trac control, active handling (or Comp mode) and all off. I use laptrax for the Z06, it automatically puts it in comp mode when ever the car starts, you can manually over ride this though. Also, for anyone who has Active handling, do not disable this mode, as it can keep ya out of the wall and reacts in micro seconds long before we could (for corrective measures).
Robert
