Is this a fpss? (pics)
Old Feb 11, 2007 | 08:53 PM
Emoney97ss's Avatar
Default Is this a fpss? (pics)
The only reason i ask is that it already had a full throttle switch on it and i'm not sure what this is... and if is a fpss how do i hook it up?
Old Feb 11, 2007 | 09:08 PM
Z284U2TRY's Avatar
yes thats a fpss. check the sticky at the top of the n20 section for diagrams
Old Feb 11, 2007 | 11:41 PM
Emoney97ss's Avatar
ok thanks...
Old Feb 12, 2007 | 11:23 AM
Emoney97ss's Avatar
i read how the wiring goes, but i'm still a little confused on how it works... i know it turns the the nitrous off if the fuel pressure drops below a certain point but how does it know what that point is?
Old Feb 12, 2007 | 11:37 AM
dsmawd350's Avatar
on the top theres a little rubber black plug pull that off and you can set it higher or lower to what psi it turns it off at
Old Feb 12, 2007 | 10:16 PM
Emoney97ss's Avatar
ok i'll check it out in the morning when i get some light outside....
Old Feb 13, 2007 | 04:43 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Most of the EFI FPSS are set at 35psi from the manufacturer - doesn't mean that's where yours is now (someone could have changed it).
I would definitely check it out using an accurate pressure gage...
Old Feb 13, 2007 | 08:36 AM
mx721suzuki's Avatar
Would you turn the screw in or out to raise the setting?
Old Feb 13, 2007 | 08:46 AM
01Z28M6's Avatar
It has been a while since I set mine so I can't remember but you can check that function with a multimeter across the terminals. Start the engine and check for continuity. Then turn the screw in or out until the multimeter shows connect or disconnect, which ever is opposite of the condition before adjusting. This will tell you for sure which direction does what.
Old Feb 13, 2007 | 03:04 PM
Emoney97ss's Avatar
thats what i was going to ask its like a screw in there but how do u know what its set at?
Old Feb 13, 2007 | 03:07 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
here is a quick rundown on how to adjust the FPSS....
Remove the bottle from the car......Take the fuel line off the nozzle....have an assistent hold the fuel line into a catch can.....bring the vehicle up within the RPM window and activate the kit......slowly tighten the adjusting screw until the sytem starts to pulse/shut down, then back the screw off 3/4 of a turn
Old Feb 13, 2007 | 06:00 PM
Emoney97ss's Avatar
what if you have a dry kit?
Old Feb 13, 2007 | 06:35 PM
1QUIKWS6's Avatar
To adjust the switch you remove the rubber plug from the top of the switch. Insert the proper hex wrench, turn clockwise to increase the setpoint, and counterclockwise to decrease the setting.
The switches are generally adjustable in a range of 25-60psi
Old Feb 13, 2007 | 07:45 PM
Emoney97ss's Avatar
whats a good psi around 50-55ish?
Old Feb 13, 2007 | 09:29 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
for a dry you would have to remove the nitrous line from the nozzle and repeat the same steps
