wiring tips
Old Feb 17, 2007 | 03:50 PM
SEDUCE's Avatar
Default wiring tips
hey guys i have a zex wet kit with a purge and i was just wondering if someone can do me a wiring diagram for it with a switch for the nos and a push button switch for the purge thanks alot
also can someone show me a pics of their fuel line to nmu please
Old Feb 17, 2007 | 05:55 PM
SEDUCE's Avatar
Any One???
Old Feb 18, 2007 | 05:46 AM
SEDUCE's Avatar
Can Someone Here Help Me At All I Am Trying To Get This Installed And I Am Stuck Cheers
Old Feb 18, 2007 | 09:02 AM
01Z28M6's Avatar
I installed the 82026 wet kit with a purge but can't come up with a visual diagram. I can answer some questions and tell of the things I did but that might not be what you are looking for. If a text reply will do, let us know and I'll be as clear as I can.
Old Feb 18, 2007 | 02:43 PM
SEDUCE's Avatar
thanks mate yeah i just need a wiring diagram if i can to help me out.
which wire out of the three does the whit one go to ???on the tps
Old Feb 18, 2007 | 04:57 PM
BOTTLEFEDLS1Z's Avatar
Did you look at the stickies at the begining of the N20 section? Some sponsors have some good wiring diagrams that will help ya out.
Old Feb 18, 2007 | 07:56 PM
01Z28M6's Avatar
White wire clips to the blue. That will be the variable signal voltage that the pcm reads. Take note; the hook-up caused a fast idle for my application and interfered with my A4 shifting. Zex (Comp Cams) sent a 9k resistor to fix the problem.
I can walk you through the rest of the installation but need to get some clarity of thought back if you know what I mean.
Old Feb 19, 2007 | 04:21 AM
SEDUCE's Avatar
Thanks mate so the white wire to the blue on the tps sensor?
mine is manual 6 spd so hope it dont play up.
i looked threw all the wiring diagrams but none with what i want
