is this a good piston for a nitrous motor?
Old Mar 19, 2007 | 03:12 PM
JDP's Avatar
JDP
Default is this a good piston for a nitrous motor?
ross pistons part #99838
bore 3.905, stroke 3.622, rod lenth 6.098, compression height 1.326, -4cc valve relief.
they are on a set of eagle h-beam rods, im going stock crank, i was just wondering if these pistons could handle a big shot.
i know compression height has a lot to do with it and ring gap, let me know what you people think because i have the chance to get a decent deal on them
Old Mar 19, 2007 | 05:33 PM
Lythropus's Avatar
most people just say to make sure it's a 2618 alloy with the proper ring spacing and gap...
i don't know if those are the same material or not...
Old Mar 21, 2007 | 03:44 PM
JDP's Avatar
JDP
any other opinions?
Old Mar 21, 2007 | 03:49 PM
1997bird's Avatar
It should be fine up to about a 200 shot if you talk to Ross. I know that they will handle a 250-300 shot without a problem. Just make sure that your ring end gap has been filed for the larger doses of n2o.
Old Mar 21, 2007 | 04:44 PM
JDP's Avatar
JDP
ya, well if i do spray its going to be a hefty amount, im not going to say how much because i know certain people are sneaky and search my posts. who knows, i might stay all motor this year, im not decided yet
i heard compression height has a lot to do with how much spray it can handle and ring gap is a big factor too. i just need to get some money so i can decide what im going to do
Old Mar 21, 2007 | 10:56 PM
losiguy's Avatar
Old Mar 22, 2007 | 10:11 AM
1997bird's Avatar
I know that a 1.25" comp height on a reverse dome JE piston will support a 1500 HP twin turbo 347 (4.125" x 3.25") old school SBC.
Old Mar 22, 2007 | 12:02 PM
WE TODD DID's Avatar
Compression height has nothing to do with it. It is the distance from the deck of the piston to the first ring land, and the distance from the first ring land to the second ring land. A good nitrous piston should have a minimum distance of .300 between both.
Old Mar 22, 2007 | 03:18 PM
JDP's Avatar
JDP
i guess you learn something new everyday
Old Mar 22, 2007 | 03:19 PM
JDP's Avatar
JDP
Originally Posted by losiguy
im kicking your *** chad.
looks like i might have a new gameplan for this year, lol
Old Mar 22, 2007 | 03:25 PM
losiguy's Avatar
Me? Man you gotta tell me I told you its only fair
Old Mar 22, 2007 | 03:57 PM
JDP's Avatar
JDP
livernois doesnt pay you to antagonize me on here, dont you have something to put into the sponsor sales and specials.
youll know what i have when its done, if it gets done, lol
Old Mar 22, 2007 | 06:21 PM
JDP's Avatar
JDP
ok, what pistons would you reccomend for a big shot? i tried searching for answers but search is fucked up again
Old Mar 22, 2007 | 10:12 PM
1997bird's Avatar
I guess that the JE Piston's tech that took my order doesn't know what he is talking about. Did it occur to you that there needs to be a certain distance between the piston face and the wrist pin? That was JE's worry, they didn't want to boil the oil off of the wrist pin from to much heat absorbtion.
Old Mar 23, 2007 | 11:14 AM
Nope, its never occurred to me because I've built hundreds of nitrous engines with various compression heights, and I have never had an issue. The only time compression height becomes a factor, is in larger cubic inch nitrous engines where you have less compression height, due to rod/stroke combinations. With less compression height, you can't run as much ring land on the pistons. And btw, I don't use JE pistons for nitrous applications because they don't make good nitrous pistons. They may have an issue with boiling the oil from the pins because there is no material around the pins to dissipate heat from the pin. The only time I even consider JE pistons is in a n/a engine.
Old Mar 23, 2007 | 02:19 PM
1997bird's Avatar
So when I was having this custom set of piston's made they never thought to add material around the wrist pin? I am not talking a off of the shelf set of piston's here. These were custom made for the application. I guess JE's commercial account tech's are not smart enough to properly build a set of piston's, but you are?
Old Mar 23, 2007 | 03:02 PM
Nope, but I'm smart enough to buy a good set of pistons!
Old Mar 23, 2007 | 03:18 PM
JDP's Avatar
JDP
well who do you go to for your nitrous pistons?
Old Mar 23, 2007 | 03:24 PM
Venolia, ross, and wiseco are the three I use most. Just depending on what I'm building.
Old Mar 23, 2007 | 03:31 PM
JDP's Avatar
JDP
i assume you go with a custom piston, and not an of the shelfer.
