Jets for a 150 whp shot
Old Mar 21, 2007 | 12:31 PM
Dynotune04's Avatar
Default Jets for a 150 whp shot
I run a dynotune wet kit. what jets will i need to run a 150 whp shot. i know dynotune rates there shots to the flywheel so to anyone running dynotunes kit let me kno
Old Mar 21, 2007 | 01:34 PM
Lythropus's Avatar
These are the conservative jets I used with my dynotune kit
Nitrous/ Fuel_____CHP/RWHP
42/24__________ 75/68
48/28__________100/88
57/32__________150/124
60/34__________160/138
62/36__________175/150
Anything past that and your basically out of noid, double check the jet calculator on their site.
Old Mar 21, 2007 | 03:11 PM
Dynotune04's Avatar
thanks
Old Mar 21, 2007 | 07:52 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Thanks Lythropus!
If you need more power you would need to go with one of our bigger solonoids.
Dean
Old Mar 27, 2007 | 04:30 PM
Dynotune04's Avatar
Originally Posted by DynotuneN2O
Thanks Lythropus!
Dean
when i bough the kit i upgraded to the jumbo solenoids as you suggested.
however i have a question about your two stage window switch. i have the msd digital switch now but i want to do a 1st gear lockout. i was wondering if
you can run a 1st gear lockout with your window switch if im only running a single stage set up.
Old Mar 27, 2007 | 04:38 PM
Beer99C5's Avatar
Originally Posted by Dynotune04
i was wondering if you can run a 1st gear lockout with your window switch if im only running a single stage set up.
Tape up the ends of the Second Stage and tie wrap them out of the way.
Old Mar 27, 2007 | 05:38 PM
99Silverado5.3's Avatar
What beer said...also throw the wires in some wire loom also.
Old Mar 27, 2007 | 06:45 PM
BTLFEDSS's Avatar
One thing you need to figure out is what your fuel pressure is rated!!!Sneakers
BTLFEDSS
Old Mar 27, 2007 | 08:53 PM
Dynotune04's Avatar
i think its 38 or 42 not sure. with the vt stage 2 cams i think im gonna need a fuel pump and maybe some injectors. maybe i shoulda taken that walboro off your hands. you get your cam yet poke?
Old Mar 28, 2007 | 08:12 PM
nate-roth's Avatar
Your ford's fuel pressure is lower, so you need a different fuel jet than LS1 cars. Pressure is around 40. Dynotune has a jetting calculator on the website.
