TWO FREE DYNOTUNE Electronic Nitrous Activation "TPS" Switch’s
LS1TECH Sponsor
We are just coming off our best quarter ever and want to again thank the LS1 Tech community!
We are offering a FREE DYNOTUNE Electronic Nitrous Activation "TPS" Switch’s to TWO lucky winners!
http://www.dynotunenitrous.com/store...?idproduct=105
This Electronic switch simply runs off your Throttle position sensor output (Works on all TPS sensors even the newer GM fly by wire set-ups!
It has an super bright tri-Color LED to indicate when the output is on and its trip point is fully adjustable via a program button. Simple installation and a rugged fully potted enclosure allows you to mount it in the engine compartment and ensures flawless operation.
Its micro package allow you to mount it anywhere (It is smaller than your nitrous relay). It has two outputs, one sends out a 12V source and the other is a wire that is grounded when activated. This feature makes it compatable with all window switches, nitrous controllers, etc.
As always no need to purchase anything - just post your thoughts!
Thanks again guys and this raffle will end April 30, 2007.
Dean
Dean
