Aluminum nitrous fittings
8 second mod
Originally Posted by Ping King
so regular aluminum AN fittings would be ok for 1000+ psi of nitrous pressure? im just trying to get a definate answer for future reference.
the basic an fitting is good for maybe 100 psi or so.
a nitruos fitting is pressed on ect.
the size of the nut is the same, and the conectors are the same. meening, ok a noid take a 3/8th pipe thread and you get a 3/8 to 6 an. yes its an an size, and fine for a nitrous feed line, but the feed line or anything under pressure is a no go.
again, the small conecters/redusers ect are ok, but to make a line, no way!!!
