How much spray to beat a KB cobra?
Old May 18, 2007 | 05:59 PM
  #41
JDPZ28's Avatar
Originally Posted by gruntwork
It's basically a full bolt on cobra typically making 450 hp to the tires that slapped a 2.8 KB on it with a tune on pump gas. Nothing exotic or anything. with an IRS. As far as I know.
I don't know his dyno numbers though. I was guessing 650ish, maybe more.
Nothing exotic? I made 650rwhp in my old 03 Cobra on pump gas with a 2.2KB(again, trapped 130mph in the 1/4 mile in a full weight vert). I would imagine if he has a maximized setup, he would be pushing more than that with a 2.8KB. Sorry, not trying to be an ***, but I think anytime someone is pushing at or more than 650rwhp on pump gas on a little 281ci motor, that's pretty impressive. Good luck with the race and let us know how it turns out. Video would be nice!
Old May 18, 2007 | 06:08 PM
  #42
BLAKE 01 WS6's Avatar
Originally Posted by xBROKEx
how does a 150 shot only add 60 hp
sorry typo....560
Old May 18, 2007 | 06:26 PM
  #43
JEB99TA's Avatar
With as much power as you're making in a A4 ... I say 100 shot and that's all you'll need to beat him. Right now, your sig shows you should be about a 11.6-11.9 car, depending on your weight ... good track conditions and MT street drag radials. 100 shot should put you right at about flat 11's ... high 10's with a little weight reduction. It'll be a helluva good race for sure. I'd go 150 shot for insurance ... this guy may have more motor than you think. Here's a better-than-average KB2.8 Cobra run ... at least from what I've seen.
http://videos.streetfire.net/search/...e47e454f49.htm
Old May 18, 2007 | 08:38 PM
  #44
gruntwork's Avatar
Thanks man, I saw that vid before, It's a good one. The KB was out on him 2 cars or so. I think the KB must be in the low 130 trap range. I figured I would trap around 130ish on a 150 shot, maybe a lil more on the 200. Does this sound resonable?
Old May 20, 2007 | 11:35 AM
  #45
=ZoomZ='s Avatar
this was a 250/2 stage kit Vs a kb cobra on 26 lbs and a 100 shot .
http://catchcans.com/videos/Sprayed%...100%20shot.wmv
Old May 22, 2007 | 10:06 PM
  #46
gruntwork's Avatar
Wow! that thing rocks! What is the rest of your setup? How did you spray-what stage at what mph? any track times?
Old May 23, 2007 | 09:06 AM
  #47
=ZoomZ='s Avatar
LQ9 408 , 250 whp shot in 2 stages , 125 on the hit and the other 125 two seconds later .
Best time so far has been a 10.54@134 on one kit , but im spraying a 350 now so i have no clue how fast it actualy is .
Old May 24, 2007 | 12:23 AM
  #48
smok'nZ's Avatar
MASS seller approved
are you an auto? and what gears also your car really moves
Old May 24, 2007 | 07:58 AM
  #49
=ZoomZ='s Avatar
Stage 5+ 4L65e and 342 gears .
Old May 25, 2007 | 08:00 AM
  #50
BLNLS1/RX7's Avatar
None.
Old May 26, 2007 | 09:05 PM
  #51
JayplaySS's Avatar
Moderator
My 99 SS h/c full bolt on had a 150shot. I have a 2.8KB Cobra solid rear. You will need a 200+. My .02, good luck.
