my bottle size.
Old May 18, 2007 | 07:04 PM
95LT1963's Avatar
Default my bottle size.
how do u tell what size bottle u hav e....i got a used kit and i thought that the bottle was a 10 pound nos bottle.......it say that it holds 10 lbs of nitrous.... and it should weigh 25 lbs with it full of nitous...so would that make it a 25 pound bottle....
Old May 18, 2007 | 07:34 PM
JDP's Avatar
JDP
the "pound" the bottle is rated at is the amount of nitrous it holds, your 25 pound bottle holds 10lbs of nitrous, so it is a 10lb bottle
Old May 18, 2007 | 08:19 PM
95LT1963's Avatar
well i orderd a 10 lb bottle bracket from NOS and it does not fit... the circumfrence of the bottle
Old May 18, 2007 | 08:24 PM
daniel6718's Avatar
it wont fit perfectly......
should ahve a sticker on it that says something like 14.5 empty, 24.5 full
but that weight its a 10 pound a 15 i think it 22 pounds or so empty 37 full?
Old May 18, 2007 | 08:29 PM
95LT1963's Avatar
weight of cyl and gas----24lbs. 12 oz.
weight of cyl empty------14lbs. 12oz.
weight of gas------------10 lbs. 0 oz.
that is what the badge says on the side of the bottle
Old May 19, 2007 | 02:19 AM
SSDriver's Avatar
you have a 10 pound bottle, the brackets wont close all the way when you tighten them. Thats how they are designed.
Old May 19, 2007 | 12:39 PM
JDP's Avatar
JDP
then put the bottle down and walk away
10lb and 15lb bottles are the same diameter, the 15lber is just longer
Old May 19, 2007 | 06:55 PM
95LT1963's Avatar
well i got the bracket to fit..but i could not use the original bolts i had to use some of my own bolts from work so it would work so i got it to work ...thank you all...
