Nitrous Dyno...finally
Old May 28, 2007 | 01:09 AM
TwistedSS's Avatar
Default Nitrous Dyno...finally
So, I finally put the SS on the DynoJet at the G11 F-body gathering. I was impressed.
My car is a 2001 SS M6
-Custom dry kit
-LS7 Clutch/LS2 flywheel
-SLP lid and bellows
-TSP Rumbler cat-back
-Poly trans/torque arm mounts
-Stock Hurst shifter with WS6 short stick
-51,000 Miles
-NGK TR-6's gapped at .038
Stock manifolds, Stock fuel pump, stock injectors, stock everything...except nitrous.
Results:
NA run- 330.2 HP/343.6 TQ
Nitrous- 458.2 HP/482.7 TQ
Will post graphs soon...also can't wait to get to the track!
Old May 28, 2007 | 01:52 AM
BayAreaSS's Avatar
Good numbers....the N/A numbers are very good for your mods.
Old May 28, 2007 | 01:54 AM
camaro4me's Avatar
what size shot??
Old May 28, 2007 | 01:56 AM
BayAreaSS's Avatar
Originally Posted by camaro4me
what size shot??
+1..........looks like a 125ish shot
Old May 28, 2007 | 08:18 AM
01_ram-air's Avatar
Very nice numbers man.
Old May 28, 2007 | 12:40 PM
TwistedSS's Avatar
what size shot??
Well it wouldn't do anything with a .059 jet, so I upped it to .073. I figure with my setup, i'm losing LOTS of power due to the placement of the nozzle and being a single nozzle. So its actually making 128 hp and 139 ft lbs. Guess you can call that a 125 shot.
Old May 28, 2007 | 12:43 PM
TwistedSS's Avatar
I think it would have made a few more NA HP and TQ if I would have removed the air filter...lol
Also i'm running NGK TR-6's...thats colder than stock, so I probably lost a few ponies there. Anyone think the LS2 flywheel (heaver) caused a little more drivetrain loss?
Old May 28, 2007 | 01:01 PM
Robert56's Avatar
Good job, now go have some fun.
Robert
Old May 28, 2007 | 02:34 PM
TwistedSS's Avatar
Any guesses on 1/4 ET? I'll be going to track on Thursday...I have nice new Nitto 555's in 285/50/17 and they do fairly well and I dont plan to spray first gear...yet.
Old May 28, 2007 | 02:41 PM
bad6as's Avatar
yea i think the ls2 fly wheel will dyno a lil lower. with thoes street tires i think you will hit a low 12 at a mid 11's mph
Old May 28, 2007 | 03:57 PM
caliswangin916's Avatar
did you log inj DC? what was it at?
Old May 28, 2007 | 08:40 PM
TwistedSS's Avatar
Didn't log it..but I need to. AF's looked good, so DC is probably within tolerance.
Old May 29, 2007 | 01:32 AM
bird2002's Avatar
I cant wait to hear what you run at the track. What does DC mean??
Old May 29, 2007 | 05:52 AM
2001z's Avatar
well if your running street tires i think your gonna be disapointed with your times. Get some drs and then get those numbers!!
Old May 29, 2007 | 05:09 PM
BobDoLe's Avatar
.073 jet???
my guess is that you're spraying onto the air filter with the nozzle placed on the radiator support under the air box?
otherwise, isn't that more like a 200+ rw shot? ...on stock injectors and fuel pump....
what was your bottle pressure?
Old May 30, 2007 | 02:35 PM
TwistedSS's Avatar
Originally Posted by BobDoLe
.073 jet???
Bottle pressure was perfect at 950 psi. True, the .073 jet would be good for 200+ hp if it was set up for it. Truth is, im running a #4 feed line, little bitty solenoid with two 90* swivel fittings, compucar nitrous filter, and spraying into the side of the airbox with a single fan type nozzle. May not be the most efficient system in the world, but i've got less than 200 bucks in the entire system. I had a .059 jet stuffed in there, and I could hardly feel a thing..taking a buddy's advice (hes been working with nitrous for 20+ years now) I jetted up and you can see the numbers that i'm making. Besides, the solenoid itself won't support a 200 rwhp shot.
Old May 31, 2007 | 04:12 PM
99Silverado5.3's Avatar
Nice numbers, get it to the track and let us know how she did!
Duty Cycle
Old May 31, 2007 | 05:04 PM
1999ssls1's Avatar
I think I talked to you at G11 saturday night. You had the buddy with Nassty on the tag? I
Old May 31, 2007 | 08:09 PM
ls1 jeff's Avatar
What was your A/F ratio on the spray? Any way you could post the graph?
Old Jun 1, 2007 | 12:20 AM
TwistedSS's Avatar
Nope, sorry...wasnt me. Allthough I was at G11.
